This add-on replaces Ctrl+G by its own functionality - creating groups using regular instances
In the add-on "Group" - it is an instance, that can be edited (in the scene called "Library") by pressing Tab
Ctrl+G - Make Group (Instance) from selected objects (F9 (adjust last operation) to set center of the group and set a name)
Tab - Opens group edit mode
Deselect everything and press Tab - Return to scene.
Ctrl+Alt+G - Ungroup
Ctrl+Shift+G - Advanced options like make single user, and change instance (Replace chair by another chair).
This add-on uses regular Blender instances, so you can send your blend file with "groups" made by this add-on, even if your co-worker haven't this add-on installed.
Take a look at my other goods: Synchronize Workspaces | Folds Modifier
Add walkaround for issue https://projects.blender.org/blender/blender/issues/125335
tool ini sangat berguna ternyata
عالی هست. از زمانی که از تری دی مکس اومدم بلندر دوست داشتم این قسمت به بلندر اضافه بهش که بالاخره با این اددان شد.
