Extensions
  • Home
  • Add-ons
  • Themes
  • Approval Queue
  • About
  • Upload Extension
  • Sign in
  • BLENDER.ORG
    • Download
    • What's New
    DEVELOPMENT
    • Roadmap
    LEARNING & RESOURCES
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
All Add-ons
Add-on Parallax Node
Parallax Node
Adds parallax node for shader nodes.
Add-on by MultLabs
About What's New Reviews Version History
Parallax Node
A Blender add-on that provides custom nodes for creating parallax mapping effects in shader materials. Many parallax node setups already exist, so the concept itself isn’t new. What makes this one truly different is its user-friendly design. Instead of a complex node group, this implementation is a single, special node that directly contains the Height Map texture and allows you to control the iteration count internally by adjusting the step parameter.
What is Parallax Mapping?
Parallax mapping is a technique used in 3D graphics to enhance the illusion of depth and detail on flat surfaces without adding actual geometry. It works by displacing texture coordinates based on a height map (elevation image) and the viewing angle, creating the appearance of surface relief and depth.
Features
  • Custom Parallax Node: A shader node that implements parallax mapping with adjustable parameters
  • Seamless Integration: Integrates directly into Blender's shader node editor
  • Configurable Steps: Adjustable iteration count for quality vs performance balance
  • UV Map Support: Works with custom UV layers
  • Real-time Preview: Works with Cycles and EEVEE
Usage
Adding the Parallax Node
  1. Open the Shader Editor and create or select a material
  2. Press Shift + A to open the Add menu
  3. Navigate to Paralax Nodes > Parallax
  4. Connect vector output into textures inputs like this:
Closure setup: Closure setup
Image setup: Image setup
Node Parameters
The Parallax node provides several adjustable parameters:
  • Elevation Image: The height/displacement map texture that defines surface relief
  • UV Map: Select which UV layer to use for the parallax effect if you are using several UV maps
  • Steps: Number of iterations (1-64) - higher values provide better quality but slower performance
  • Strength: Scale of the parallax effect (0.0-100.0) - controls how pronounced the depth effect is
  • Bias: Texture tweaking bias (0.0-2.0) - fine-tunes the height mapping
Technical Details
This add-on implements parallax occlusion mapping using multiple texture sampling iterations. Each iteration refines the texture coordinate offset based on the height map, creating a convincing depth effect that responds to viewing angle changes.
Attribution
Some code in this project is adapted from or inspired by the Noise Nodes add-on by haseebahmed295.
License
This project is licensed under the GNU General Public License v3.0 or later. See the license headers in the source files for details.
Support
For issues, questions, or contributions, please contact: crantisz@gmail.com
Take a look at my other goods: Synchronize Workspaces | Folds Modifier | Quick Groups | Staircase Generator
What's New
1.1.3 May 8th, 2026
Added a new Camera Type setting to improve parallax behavior with panoramic cameras.
This change is justified by known Blender panoramic/vector transform issues (see Blender bug report). The previous automatic fix approach could produce visual artifacts, so it has been removed and replaced with explicit per-camera fix modes.
  • Default - no fix
    Use for standard (non-panoramic) cameras: Perspective, Orthographic and Custom cameras
  • Panoramic
    Use for panoramic cameras except Mirror Ball.
  • Mirror Ball
    Use for panoramic cameras in Mirror Ball mode.
See all versions
Permissions
Developer
MultLabs
Rating
(28)
Version
1.1.3
Updated
1 mo
Published
Sept. 1st, 2025
Downloads
28623
Size
12.4 KB
Blender 5.0 and newer
Website
multlabs.com
Report Issues
blenderartists.org/t/parallax-node-add-on/1610001
License
Material Node
...or download and Install from Disk
  • 12.4 KB
Reviews
See all
  • jc4d
  • v1.1.1
  • 2 mo
Fantastic addon!
  • Bayu-Itra
  • v1.1.1
  • 3 mo
We have been waiting for the official optimized version of Paralax Feature for a while, and it comes out great! This feature alone would change how the indie animation production works from now on.
  • Thierry.Ak
  • v1.0.0
  • 4 mo
It doesn't work, it's rubbish !
  • MultLabs replied
  • 4 mo
Install the latest version, please. Old versions have some bugs.
5.0
28 reviews
5
4
3
2
1
Rate this Add-on Report an issue
  • About
  • Terms of Service
About
  • Blender Foundation
  • Blender Institute
  • License
  • Logo & Trademark
  • Credits
  • Code of Conduct
Organization
  • People
  • Jobs
Blender Network
Download
  • Latest Blender
  • Blender LTS
  • Previous Versions
  • Experimental Builds
  • Source Code
  • Requirements
  • Benchmark
  • Flamenco
Extensions
  • Add-ons
  • Themes
Developers
  • Get Started
  • Roadmap
  • Docs
  • Forum
  • YouTube
  • Python API
  • Tools & Pipeline
Support
  • Community
  • FAQ
Get Involved
  • Education
News
  • Press Releases
  • User Stories
Blender Conference
Follow Blender
Support Blender
  • Donate
  • One-time Donation
