Extensions
  • Home
  • Add-ons
  • Themes
  • Approval Queue
  • About
  • Upload Extension
  • Sign in
  • BLENDER.ORG
    • Download
    • What's New
    LEARNING & RESOURCES
    DEVELOPMENT
    • Developers Blog
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
All Add-ons
Add-on Per-Camera Resolution
Every camera should have its resolution.
Add-on by pioverfour
About What's New Reviews Version History
A portrait shot of Suzanne. A custom resolution of 1000×1500px has been selected, and a timeline marker is bound to a first camera. The same scene on frame 2, with another marker to switch cameras. This time a landscape format of 1500×1000px is what we want.
Instead of having a globally-defined scene resolution, this add-on allows you to set a resolution for each camera. Whenever you switch cameras, either manually or through timeline markers, the scene resolution will get updated to the camera’s.
You can find the camera resolution settings in the Object Data properties, under the Camera panel.
Rendering
Animating the resolution is not supported by default in Blender, and regular animation rendering will only use the resolution at render start.
This add-on provides a new Render Animated Resolution operator which works around this limitation. Note however that starting a render this way will lock the interface until the render is complete, or until Blender is killed.
Baking render borders
In addition to providing direct controls for each camera’s resolution, this add-on allows you to create a new camera by setting a render border inside the camera view in the 3D viewport (Ctrl + B), and clicking Bake Render Border in the Custom Resolution panel.
A new camera is created, which uses the exact area defined by the border. This allows you to select multiple cropped areas in a camera.
Known issues
This add-on uses a workaround to animate the camera resolution, which can sometimes cause stability issues. If you encounter such issues, try disabling the add-on.
The add-on is currently available in English, French, and simplified Chinese. If you’d like to help translate it to your language, please open an issue.
Translators
  • Simplified Chinese: deathblood.
What's New
2.3.0 November 13th, 2024
  • Add simplified Chinese translation, thanks to deathblood!
See all versions
Permissions
Developer
pioverfour
Rating
(31)
Version
2.3.0
Updated
7 mo
Published
May 28th, 2024
Downloads
21363
Size
10.9 KB
Blender 4.2  and newer
Website
projects.blender.org/pioverfour/per_camera_resolution
Report Issues
projects.blender.org/pioverfour/per_camera_resolution/issues
License
GNU General Public License v3.0 or later
Scene Camera
...or download and Install from Disk
  • 10.9 KB
Reviews
See all
  • Calogero
  • v2.3.0
  • 1 mo
This should be in Blender by default, good job.
  • dursunumit
  • v2.3.0
  • 2 mo
nice
  • Kucha
  • v2.3.0
  • 2 mo
5.0
31 reviews
5
4
3
2
1
Rate this Add-on
  • About
  • Terms of Service
Download
  • Latest Blender
  • Blender LTS
  • Blender Benchmark
  • Previous Versions
  • Experimental Builds
  • Source Code
  • Release Notes
  • Requirements
Organization
  • People
  • Jobs
About
  • Blender Foundation
  • Blender Institute
  • License
  • Logo & Trademark
  • Credits
Articles
  • News
  • Press Releases
  • User Stories
Get Involved
  • Dashboard
  • Development
  • Education
Support
  • Community
  • FAQ
Developers
  • Get Started
  • Docs
  • Forum
  • YouTube
  • Python API
Blender Conference
Follow Blender
Support Blender
  • Donate
  • One-time Donation
