UV Maps+ (UV Maps Plus) is a Blender Extension that removes the 8 UV map limit, allows for UV reordering, and adds batch editing tools for managing UV maps across multiple objects.
▲/▼ arrows or move directly to top/bottom💚 UV map sync now works in Edit mode (was Object mode only)
💚 Entering Edit mode auto-syncs UV selection across all selected objects
💚 Copy/paste UVs now works across multiple objects simultaneously
💚 Undo no longer breaks UV sync across objects
💚 Fixed sync not always triggering when clicking UV maps in the list
💚 Fixed potential crashes with objects that have no mesh data
Maybe not hyper-necessary if you're a beginner with Blender, but for larger-scale projects that require multiple UVMap assortments, and just in general for quality of life, this plugin is great. I think the most helpful element of it is the ability to just reorganize UVMap assignments, which for some reason is just NOT a vanilla feature of Blender's UVMap display section in the properties panel? Seems like an oversight on the Blender Foundation's part, but this plugin certainly helps address that.
