Extensions
  • Home
  • Add-ons
  • Themes
  • Approval Queue
  • About
  • Upload Extension
  • Sign in
  • BLENDER.ORG
    • Download
    • What's New
    LEARNING & RESOURCES
    DEVELOPMENT
    • Developers Blog
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
All Add-ons
Add-on Quick Studio Light
Quick Studio Light
Simple and fast lighting.
Add-on by Shuimeng
About What's New Reviews Version History
Are you crazy because of the frequent manual search for the angle of the light, do not take the time and effort to constantly rotate and move the light, this is a tool to assist you in lighting, using it can be smart and fast to illuminate your product, early off work than anything else. (The light node in the demo is not included in the extension at the moment, maybe later I can find a way to add this node into the code)
Usage: shift+R to enter the light mode, the mouse falls on the object will automatically control the light to light up the desired position. Press space will switch to fine-tuning mode, when you confirm the angle, the left mouse button to confirm, the right button or esc to cancel the adjustment。 ctrl+right mouse button will trigger the lighting parameter panel, the panel in addition to the regular lighting parameters, will also automatically read the parameters available in the light node group, convenient to adjust the node parameters。 in the preferences you can modify the shortcut keys you want!
What's New
1.0.1 January 30th, 2025
Optimized some problems with the code. In light mode, press G to adjust the light distance, press S to scale the light, left click to confirm the adjustment, right click to cancel the adjustment. Optimized the occupancy problem of the same shortcut key in other modes, now only selecting the light in object mode will trigger the light's function.
Permissions
Developer
Shuimeng
Rating
(3)
Version
1.0.1
Updated
4 mo
Published
Jan. 28th, 2025
Downloads
10306
Size
38.4 KB
Blender 4.2  and newer
Report Issues
discord.gg/dZyvehTbtQ
License
GNU General Public License v3.0 or later
3D View Lighting
...or download and Install from Disk
  • 38.4 KB
Reviews
See all
  • Tarek-4
  • v1.0.1
  • 1 mo
Gooooood
  • chen-pan
  • v1.0.1
  • 1 mo
插件蛮好的,就是能否给shift+r后就直接根据鼠标位置调整灯光了,如果我灯光照亮的位置已经调整好了,只需要空格键进入局部调整,那又要重新定位灯光焦点位置后再按空格,能否加个快捷键,shift+r 后只是进入操作符,但不会马上调整灯光啊? 再就是能否给插件添加个中文翻译字典啊! 感谢
  • Shuimeng replied
  • 4 w
如果是需要只进入空格微调模式,避免二次进入调整模式造成的灯光重新定位,可以先【把鼠标移动到空背景下】,不要落在模型上,就可以shift+r进入调整模式直接按空格切换为微调模式
  • Kompakt
  • v1.0.1
  • 1 mo
One of the smoothest addons I've ever used
5.0
3 reviews
5
4
3
2
1
Rate this Add-on
  • About
  • Terms of Service
Download
  • Latest Blender
  • Blender LTS
  • Blender Benchmark
  • Previous Versions
  • Experimental Builds
  • Source Code
  • Release Notes
  • Requirements
Organization
  • People
  • Jobs
About
  • Blender Foundation
  • Blender Institute
  • License
  • Logo & Trademark
  • Credits
Articles
  • News
  • Press Releases
  • User Stories
Get Involved
  • Dashboard
  • Development
  • Education
Support
  • Community
  • FAQ
Developers
  • Get Started
  • Docs
  • Forum
  • YouTube
  • Python API
Blender Conference
Follow Blender
Support Blender
  • Donate
  • One-time Donation
