Extensions
  • Home
  • Add-ons
  • Themes
  • Approval Queue
  • About
  • Upload Extension
  • Sign in
  • BLENDER.ORG
    • Download
    • What's New
    DEVELOPMENT
    • Roadmap
    LEARNING & RESOURCES
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
All Add-ons
Add-on img2mat_pro
img2mat_pro
Extract color materials and paint palettes from images.
Add-on by stevewarner
About Reviews Version History
Images to Color Materials Basic Useage Adding Lock Colors Accessing Color Palettes
Image 2 Material Pro
Extract materials and color palettes from any image. Generate production-ready materials, swatches, labels, Blender Palettes, and Assets with one click.
Highlights
  • It just works. Load an image. Click Generate Materials. Done.
  • Simple UI with Advanced Options
  • K-Means (RGB, Comfy) or Poster Unique extraction
  • Lock Colors allow you to ensure the specific color you want gets created as a material.
  • Auto-sized labels that never exceed swatch width
  • Asset-ready materials in the click of a button
  • Image Editor sync will use whatever image is visible in the Image Editor
  • Plain English Color Names created automatically
  • Blender Palette creation for your texture painting needs
How to Use
  1. Open View3D → Sidebar → Img2Mat.
  2. Load an image into an Image Viewer window. Make sure the Sync with Image Viewer checkbox is enabled at the top of the Img2Mat window.
  3. Choose how many colors you want to pull by adjusting the Palette Size (default 8).
  4. If you want to ensure a color gets added as a material, add a Lock Color and then sample from the image. Rename the color if you'd like. You can use the custom name for this color by enabling the Use Lock Names checkbox.
  5. In Output, enable Generate Swatches/Generate Labels/Mark as Assets/Create Blender Palette as desired.
  6. Click Generate Materials.
Pro Features
This tool is designed to simply work with zero fuss. However it wouldn't be a Pro tool if it didn't offer options under the hood.
If you toggle down the Options, you'll find two separate methods for sampling.
K-Means is based on Christian Byrne's ComfyUI img2colors node. It works 99.99% of the time, however if you find that the colors aren't accurate, you can try the Poster Unique method.
Color Space will sample images in sRGB (useful for JPG, PNG, etc.) by default. If you're using an EXR or HDR file, you can set the Color Space to Linear to sRGB.
Sampling / Comfy K-Means / Lock Snapping are all settings you can play with if the tool isn't grabbing accurate colors. To be honest, I don't know what they do and I've never had to adjust them. But there there if you want to play with them.
Naming allows you to change the way the colloquial color names are applied. If you find that the color names aren't quite matching what you'd expect, you can try a different method here.
Subsurface lets you determine if the colors will impact the resulting material's subsurface scattering. Leave it at 0 for normal materials. If you're doing leaves, skin, etc. set it to 0.2. For wax, set it to 0.5.
Assets & Palette let you specify names for the assets and palettes created.
What's New
No changelog for this release.
Permissions
Developer
stevewarner
Rating
(5)
Version
1.10.0
Updated
7 mo
Published
Nov. 12th, 2025
Downloads
12117
Size
9.6 KB
Blender 4.2 LTS and newer
Website
stevewarner.com
Report Issues
github.com/realstevewarner/Img2Mat_Pro/tree/main
License
GNU General Public License v3.0 or later
Material Pipeline User Interface
...or download and Install from Disk
  • 9.6 KB
Reviews
See all
  • Danielle-Dunham
  • v1.10.0
  • 1 mo
I’ve been looking into VB6 modernization recently, and it’s impressive how structured and practical a full migration approach can be when done properly. What stood out to me is how important it is to preserve existing business logic while still moving toward a modern .NET architecture instead of just doing a direct conversion. The step-by-step process and focus on testing and optimization really make sense for reducing risk in legacy systems. https://www.abtosoftware.com/expertise/vb6-migration
  • Gust-Rasoritor
  • v1.10.0
  • 1 mo
Extracting precise palettes from images can be such a headache when you're trying to match specific design vibes. I’ve been using https://cabina.ai/tools/ai-chat-with-pdf lately to break down technical guides on color theory while I’m working on my projects. It’s way smoother than manual picking because you can actually query the data behind the visuals. This tool is a total game changer for anyone tired of guestimating hex codes.
  • OrangeYo
  • v1.10.0
  • 2 mo
GOOD!
5.0
5 reviews
5
4
3
2
1
Rate this Add-on Report an issue
  • About
  • Terms of Service
About
  • Blender Foundation
  • Blender Institute
  • License
  • Logo & Trademark
  • Credits
  • Code of Conduct
Organization
  • People
  • Jobs
Blender Network
Download
  • Latest Blender
  • Blender LTS
  • Previous Versions
  • Experimental Builds
  • Source Code
  • Requirements
  • Benchmark
  • Flamenco
Extensions
  • Add-ons
  • Themes
Developers
  • Get Started
  • Roadmap
  • Docs
  • Forum
  • YouTube
  • Python API
  • Tools & Pipeline
Support
  • Community
  • FAQ
Get Involved
  • Education
News
  • Press Releases
  • User Stories
Blender Conference
Follow Blender
Support Blender
  • Donate
  • One-time Donation
