Procedural clouds that are easy to customize!
If you'd like to support the continued development of this plugin please:
And/Or
Contribute your time to the source code at the Codeberg Repo!
See the backlog for planned features
One button creation of clouds:
Single cloud
Cloud layer
Convenient node groups to build your own clouds with
To create clouds after enabling the addon, navigate to the 3d view's sidebar and select Tool. Your find EasyCloud options under the Easy Clouds panel
Feel free to suggest any features or changes you'd find helpful
(Completed! v2.1) Separated Cycles and EEVEE shader
(Completed! v2.2) Spherical cloud create button
Modifier panel
Optimize bounding box in geonodes
Geonodes based cloud builder
Mesh based clouds inspired by this tutorial
I've started on better cloud bounding boxes using geonodes. Additionally modifier control was suggested by a user, so welcome new backlog item: "Modifier Panel" which I'll be reading up on blenders api to implement!
Great addon. Just here trying to ask a question, how do I sample the normals to generate a normal map for a 2d image?
Right now the clouds are volumetric shapes inside a simple cube/sphere. Creating meshes with geometry nodes is in the works for the next update, but progress has been slower then I'd like due to my time being taken up by work.
As a workaround for now:
thousands of thanks for all your work on the extension, wishing you loads of loads of success in implementing the earlier planned functions, improvements.
Could use some quick description in the addon. There is no location stated, no description. Wonder how they passed this addon, i mean it needs to be coded using terms.
