- MikhailRachinskiy changed review status to Awaiting Review
- 2 mo
Ready for review
Weight by Face Area
by default.This extension requests the following permission:
Export STL, PLY, OBJ files
Ready for review
Generally everything's fine. It is not a blocker issue, but it will be good if operator presets were stored inside the add-on directory, in separate folder. Access to folders outside extensions may change in the future.
P.S. I didn't get what Hollow operator is supposed to do, it just creates remeshed object scaled along normals. If you don't tick "Duplicated Hollow" it doesn't do what operator name suggests. I would advise checking that by default, or inverting the behavior and renaming the property.
...be good if operator presets were stored inside the add-on directory
There is nothing about that in migration guide. Could you please refer me to the docs for how to properly implement operator presets for extensions?
It explained in tooltip, it creates offset surface.
Hollow
is industry standard terminology and as far as I know every hollow tool implementation is done this way.
updated description, featured image, icon
uploaded new version: Add-on "3D Print Toolbox" v1.1.0
uploaded new version: Add-on "3D Print Toolbox" v1.1.1
updated description
Sign in to comment.
