Precisely move and align mesh parts and objects based on geometry and measurements from your scene with Mesh Align Plus. Watch clips on YouTube (or GIFs on the wiki) for instructions!
https://github.com/egtwobits/mesh_mesh_align_plus/
https://github.com/egtwobits/mesh_mesh_align_plus/wiki
Mesh Align Plus gives you the power to pick features in your scenes (like lines, or flat surfaces: they're called "Alignment Keys"), and align your objects accordingly. You can also edit parts of your mesh using the same basic workflow.
The features you select define how the alignment behaves. To align flat surfaces, for example, you pick a first flat surface in edit mode, then pick a second flat surface, then select something to apply the alignment to: The first surface will move to meet the second surface.
In that example, the flat surfaces you pick can come from any object, and the thing you're moving is also up to you: move one object, or many selected objects, or a mesh fragment while modeling (each workflow follows the same basic steps). You can optionally do weird stuff, like defining a flat surface with 3 verts on 3 different objects (vert selection order matters too!).
Mesh Align Plus can also capture measurements from your scene for your custom transformations. Find a line/plane intersection point, grab face normals for alignments, and measure angles between lines (a line can be an edge, or just two random verts)...and more. Define an invisible axis, for example, and align your space station to lie along it.
Everything in Mesh Align Plus follows those basic concepts: Pick some features, and choose what to apply it to. If you're doing simple stuff like aligning real faces from different objects to each other, you can use Easy Mode. For super complex alignments, though, Expert Mode gives you extreme power and flexibility for defining your keys, and the target(s) you want to move.
Expert Mode for each tool might seem scary, but it's really just a BUNCH of options that allow you to pick features in weird ways: Define a line that starts in the middle of a bunch of verts, and ends at the intersection point of a line/plane, for instance. Don't ask me why you'd need to do that, you're the expert on your own blend files! :D
This is a release candidate for Mesh Align Plus on the new extension system.
UX does seem to require PhD but it does work
Please remove '3D View' and 'User Interface' from tags, not related
There are extensive clips and docs on the wiki (and in the gallery on this page). Like Blender itself, many buttons provide many options, but if you watch the clips or read the docs the workflows are not hard.
I'll remove 3D View and User Interface (I wasn't sure what those meant as that is where the addon goes and it provides a UI).
Thanks!
Hey everyone,
Just a heads-up about a recent change regarding the licensing of add-ons on the Blender extension platform. Moving forward, all add-ons will need to be released under the GNU/GPL 3.0 license (SPDX:GPL-3.0-or-later). This is mainly to keep things simple and consistent across the board.
Previously, we accepted various licenses as long as they were compatible with Blender’s distribution. However, to avoid any confusion and streamline the process, all add-ons using the bpy API should now be presented as GPL 3 (the same license the Blender bundle is distributed). Regardless of whether the original code was under GPL 2, or something else like MIT or ZLIB.
Existing add-ons versions won't be affected. However, new updates will need to comply to the revised requirements.
Thanks for understanding, and feel free to reach out if you have any questions.
Sign in to comment.
Ready for review
