Check mesh issues directly in the Blender viewport, fix your model, and see whether the problems have been cleaned up in real time.
Suitable for:
Check Mode is the core feature of YL MeshCheckHUD.
It displays common topology issues directly on the model and shows the count of each issue type in the sidebar list.
You can fix the model while watching the results update, without manually refreshing the check.
Supported checks:
Realtime HUD displays commonly used mesh information directly in the 3D viewport, such as the triangle count and dimensions of the selected mesh. Whether you select the whole object or part of the mesh in Edit Mode, the HUD shows the result directly in the viewport.
It can display:
Heatmap Preview uses color to visualize the triangle count of objects in the scene. It also shows each object's triangle percentage, material / material slot count, and UV count in the list and HUD.
Suitable for checking:
After installation, press N to open the 3D Viewport Sidebar, then go to the YL MeshCheckHUD tab.
The add-on includes three main tools:
GNU General Public License v3.0
Added a new Edit Mode check detail view
Fixed important compatibility and stability issues
Thanks
Thanks for the report. I tried to reproduce this issue on my side, but I can’t see the overlap yet.
Could you please open a GitHub issue with a screenshot and a short note about how this bug happened? Once I can identify the cause, I’ll fix it as soon as possible
"The text in the bottom right corner (UHD info) is overlapping and squashed together. How can I fix this UI glitch?"
