Viewport Navigation Display
A Blender extension that displays an interactive camera-style overlay in the TOP orthographic view, showing the position, orientation, and field of view of other 3D viewports.
Features
- Camera-style overlay: Displays a camera icon with converging lines representing the actual field of view (FOV) based on viewport lens settings
- Accurate positioning: The overlay shows the real camera position, not just the target point
- Interactive controls:
Alt + Drag: Move the other viewport's position on XY plane
Shift + Alt + Drag: Rotate the viewport around its own axis (not orbiting)
- Auto-zoom: When dragging the camera icon toward viewport edges, the TOP view automatically zooms out to keep the icon visible
- Smart scaling: The camera overlay maintains appropriate visual size with min/max limits during zoom operations
- Customizable appearance: Adjust scale and color of the camera overlay
- Real-time sync: Changes are instantly reflected in both viewports
Controls Summary
| Action |
Control |
| Move viewport |
Alt + Left-click Drag |
| Rotate viewport |
Shift + Alt + Left-click Drag left to right |
| Height of viewport |
Ctrl + Alt + Left-click Drag down to up |
| Cancel operation |
Esc or Right-click |
Usage
- Split your Blender window to have two 3D viewports
- Set one viewport to TOP orthographic view (Numpad 7)
- Click the camera icon in the viewport header or enable in the sidebar (View tab > Viewport Navigation)
- The camera overlay shows the position, direction, and FOV of the other viewport
- Use the controls above to manipulate the other viewport
Visual Representation
- Trapezoid shape: Represents the camera frustum with converging lines showing the FOV
- Detached arrow: Points in the view direction
- Semi-transparent fill: Easy to see but doesn't obscure the scene
- Dark edges: Clear visibility of the camera shape
Requirements
Installation
- Download the extension package (.zip)
- In Blender: Edit > Preferences > Add-ons > Install
- Select the downloaded .zip file
- Enable the "Viewport Navigation Display" addon
Panel Location
- Header: Camera icon button in 3D Viewport header (only visible in TOP view)
- Sidebar: View tab > Viewport Navigation panel
License
GPL-3.0-or-later
