Extensions
  • Home
  • Add-ons
  • Themes
  • Approval Queue
  • About
  • Upload Extension
  • Sign in
  • BLENDER.ORG
    • Download
    • What's New
    DEVELOPMENT
    • Roadmap
    LEARNING & RESOURCES
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
All Add-ons
Add-on Viewport FPS
Viewport FPS
Displays frames per second in current 3D viewport.
Add-on by Pazelock
About What's New Reviews Version History
What you can achieve with this add-on example 1 What you can achieve with this add-on example 2 What you can achieve with this add-on example 3 What you can achieve with this add-on example 4 Preferences
Viewport-FPS
Viewport FPS Blender add-on
About
Viewport FPS is a simple Blender add-on that calculates and displays the frames-per-second value in your 3D Viewport. Unlike the built-in FPS counter, which is used to track animation playback frame rate, Viewport FPS displays real-time FPS directly in your 3D Viewport at all times.
Usage
After installing the add-on, you will see a gray label appear under the Snapping toggle. This label displays your current frames-per-second value.
Preferences and Personalization
To find the add-on preferences, go to:
Edit -> Preferences -> Add-ons
Type "Viewport FPS" in the search field. Click the arrow to expand the add-on information and access the preferences.
In the Preferences section, you will find settings that change the counter’s appearance and properties:
  • Show "FPS:" Label: Shows/Hides the "FPS:" text
  • Show Decimals: Shows/Hides decimal values
  • Warning FPS: If your FPS drops below this value, the display color changes (see Warning FPS Color)
  • Refresh Every N Frames: Updates the FPS indicator every N frames (set to 1 for real-time updates)
  • Font Size: Size of the FPS text
  • Position: The corner from which the offset is calculated
  • Position X: Horizontal offset
  • Position Y: Vertical offset
  • Normal FPS Color: Color used for normal FPS display
  • Warning FPS Color: Color used when FPS drops below the Warning FPS value
Feedback
Visit the link below to report an issue: https://github.com/pazelock/viewport-fps/issues
What's New
1.0.2 January 1st, 2026
Added add-on tags.
Permissions
Developer
Pazelock
Rating
(1)
Version
1.0.2
Updated
5 mo
Published
Dec. 24th, 2025
Downloads
1793
Size
3.0 KB
Blender 4.2 LTS and newer
Website
extensions.blender.org/add-ons/viewport-fps
Report Issues
License
GNU General Public License v3.0 or later
3D View System User Interface
...or download and Install from Disk
  • 3.0 KB
Reviews
See all
  • Motasim-AZiz
  • v1.0.2
  • 2 mo
Extension is weird framerate goes up even if timeline is paused
4.0
1 review
5
4
3
2
1
Rate this Add-on Report an issue
  • About
  • Terms of Service
About
  • Blender Foundation
  • Blender Institute
  • License
  • Logo & Trademark
  • Credits
  • Code of Conduct
Organization
  • People
  • Jobs
Blender Network
Download
  • Latest Blender
  • Blender LTS
  • Previous Versions
  • Experimental Builds
  • Source Code
  • Requirements
  • Benchmark
  • Flamenco
Extensions
  • Add-ons
  • Themes
Developers
  • Get Started
  • Roadmap
  • Docs
  • Forum
  • YouTube
  • Python API
  • Tools & Pipeline
Support
  • Community
  • FAQ
Get Involved
  • Education
News
  • Press Releases
  • User Stories
Blender Conference
Follow Blender
Support Blender
  • Donate
  • One-time Donation
