Change your view angle based on the selected mesh element — Face, Vertex, or Edge.
It’s easy — simply switch to Edit Mode, select a mesh element, then press the shortcut key `. You will see the available options; just select the one you want.
If you’re interested in checking out more addons, you can explore the addon collection at : https://wans7.gumroad.com/
For future improvements, please feel free to leave your feedback in the review section.
