Extensions
  • Home
  • Add-ons
  • Themes
  • Approval Queue
  • About
  • Upload Extension
  • Sign in
  • BLENDER.ORG
    • Download
    • What's New
    LEARNING & RESOURCES
    DEVELOPMENT
    • Developers Blog
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
All Add-ons
Add-on Vertex Overlap
Vertex Overlap
Alerts you to overlapping vertices in real-time.
Add-on by Shawn-Shipley
About What's New Reviews Version History
Vertex Overlap shows up under Edit in the N-Panel Real-time checking is disabled by default. It can be toggled on or off at anytime.
Vertex Overlap
Found under the Edit N-panel, Vertex Overlap is a Blender add-on that alerts you to overlapping vertices in real-time and allows you to merge them with a single click.
Have you ever started, then canceled an extrusion? If you don't remember to immediately undo your last action, you will create overlapping vertices that aren't easy to spot until you start noticing weird rendering issues or you experience odd issues while editing your mesh.
Features
  • Alerts you to new overlapping vertices in real-time. Disabled by default, but enabled with a simple checkbox.
  • Show Overlaps button will highlight vertex overlaps, so you can preview what will be merged. You must be in Vertex Selection Mode to see the highlighted overlaps.
  • You can set a custom Overlap Threshold distance. If you only want to be alerted about overlapping vertices of a certain distance. The default is 0.0001m.
  • If real-time checking is disabled, you can manually check for overlapping vertices by clicking the Check Overlaps button at anytime while in Edit mode.
  • Provides a convenient Merge Vertices button that will merge overlapping vertices by the configured Overlap Threshold distance. This is equivalent to Selecting All and then Merging by Distance. Now in a convenient single click.
  • If you select multiple objects and tab to Edit mode, the Overlapping Vertices count will reflect the number of overlapping vertices in both mesh objects combined. If you have two objects, each with 2 overlapping vertices, and select both then tab to Edit mode, Vertex Overlap will show 4 total overlapping vertices.
What's New
1.1.0 December 19th, 2024
  • Added a Show Overlaps button so you can see which vertices are overlapping. Useful if you just want to see which vertices are overlapping without merging them. You must switch to Vertex Selection mode to see which vertices are overlapping.
See all versions
Permissions
Developer
Shawn-Shipley
Rating
(3)
Version
1.1.0
Updated
6 mo
Published
Dec. 3rd, 2024
Downloads
9795
Size
16.8 KB
Blender 4.2  and newer
Website
github.com/shawnshipley/vertex-overlap
Report Issues
github.com/shawnshipley/vertex-overlap/issues
License
GNU General Public License v3.0 or later
Modeling Mesh
...or download and Install from Disk
  • 16.8 KB
Reviews
See all
  • Håkan-Fors
  • v1.1.0
  • 1 mo
Works really great!
  • Winter2Lake
  • v1.1.0
  • 4 mo
Automerge worked
  • Valery-9
  • v1.0.6
  • 6 mo
Awesome addon! I was looking for something that will at least partially replace xview from 3ds max. However, i think it misses one important option - to just select those overlapping vertices instead of merging them. Its usefull in cases where the vertices are from different meshes, and should not be merged, just moved a little.
  • Shawn-Shipley replied
  • 6 mo
Hi, thanks for the review. I added a Show Overlaps button that will highlight the overlapping vertices (by selecting them) without merging them. You just need to be in Vertex Selection mode to see which vertices are highlighted. I'm not sure if this will address your exact issue, but hopefully it will be helpful. Just update to version 1.1.0 for that new feature.
5.0
3 reviews
5
4
3
2
1
Rate this Add-on
  • About
  • Terms of Service
Download
  • Latest Blender
  • Blender LTS
  • Blender Benchmark
  • Previous Versions
  • Experimental Builds
  • Source Code
  • Release Notes
  • Requirements
Organization
  • People
  • Jobs
About
  • Blender Foundation
  • Blender Institute
  • License
  • Logo & Trademark
  • Credits
Articles
  • News
  • Press Releases
  • User Stories
Get Involved
  • Dashboard
  • Development
  • Education
Support
  • Community
  • FAQ
Developers
  • Get Started
  • Docs
  • Forum
  • YouTube
  • Python API
Blender Conference
Follow Blender
Support Blender
  • Donate
  • One-time Donation
