Extensions
  • Home
  • Add-ons
  • Themes
  • Approval Queue
  • About
  • Upload Extension
  • Sign in
  • BLENDER.ORG
    • Download
    • What's New
    LEARNING & RESOURCES
    DEVELOPMENT
    • Developers Blog
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
All Add-ons
Add-on Vertex Group Assistant
Simplifies clothing rigging for avatars.
Add-on by Maro3D
About What's New Reviews Version History
Video showing how to use the addon. Image showing where the newly added menu is located.
Add-on designed to simplify transferring vertex groups, weight paint, and armatures between objects, specifically useful for outfit creation for VRChat avatars.
Features
  • Transfer Vertex Groups: Easily transfer vertex groups from an active object and parent the selected objects to the active objects armature.
  • Delete Unused Vertex Groups: Remove vertex groups with no weight assignments from the selected objects.
  • Delete Unused Bones: Clean up armatures by deleting bones not associated with any vertex group. Optionally, duplicate the armature before modifications.
How to Use
  1. Transfer Vertex Groups:
    • Select at least two objects: the source (active) and target (There can be multiple targets selected at once).
    • Go to Object > Vertex Groups > Vertex Group Assistant.
    • Choose Transfer Vertex Groups from Active Object.
  1. Delete Unused Vertex Groups:
    • Select an objects with vertex groups.
    • Choose Delete Unused Vertex Groups to clean up zero-weight groups.
  1. Delete Unused Bones:
    • Select exactly one object with vertex groups parented to an armature.
    • Choose Delete Unused Bones and confirm the operation. If you select "Duplicate Armature," a new armature is created. Otherwise, unused bones are directly removed from the parent armature.
What's New
1.0.2 January 8th, 2025
Reupload of a Previous Extension with a New Name and Improved Features
This is a reupload of a previous extension (formerly called VRChat Outfit Helper) with a more general name and the incorporation of suggested features.
Previous Feedback for Reference:
Comment by nickberckley:
Hey,
Tool is fine, but I wonder if it's unnecessarily focused and limited by name and some hardcoding? It seems the add-on is generally a useful toolset for vertex groups, and naming it VRChat might be occluding it from other users. Is that what you want? Or is there something specific to VRChat that will not work for regular use cases?
Also, there seems to be a limit in the transfer operator for 2 objects maximum. Why's that? I believe the operator could support any number of objects if it's transferring from active to selected.
At one glance, I think OBJECT_OT_transfer_vertex_groups_from_active is completely unnecessary. It seems to be calling bpy.ops operator for transferring weights, and the only other thing it does is validate selection. It also seems to make the wrong assumption that the armature the object modifier is using is necessarily its parent, which is not always true. Is there something different happening in this operator that I'm missing?
Permissions
Developer
Maro3D
Rating
(1)
Version
1.0.2
Updated
4 mo
Published
Jan. 8th, 2025
Downloads
3682
Size
3.8 KB
Blender 4.2  and newer
Website
github.com/Maro-3D/VRChat-Outfit-Helper/tree/main
Report Issues
github.com/Maro-3D/Vertex-Group-Assistant
License
GNU General Public License v3.0 or later
Rigging
...or download and Install from Disk
  • 3.8 KB
Reviews
See all
  • Valerie-Snow
  • v1.0.2
  • 3 w
Whilst the addon does work, it could be improved. If you use a data transfer modifier with mapping set to "Nearest Face interpolated" a much better result can be achieved in stock blender.
3.0
1 review
5
4
3
2
1
Rate this Add-on
  • About
  • Terms of Service
Download
  • Latest Blender
  • Blender LTS
  • Blender Benchmark
  • Previous Versions
  • Experimental Builds
  • Source Code
  • Release Notes
  • Requirements
Organization
  • People
  • Jobs
About
  • Blender Foundation
  • Blender Institute
  • License
  • Logo & Trademark
  • Credits
Articles
  • News
  • Press Releases
  • User Stories
Get Involved
  • Dashboard
  • Development
  • Education
Support
  • Community
  • FAQ
Developers
  • Get Started
  • Docs
  • Forum
  • YouTube
  • Python API
Blender Conference
Follow Blender
Support Blender
  • Donate
  • One-time Donation
