ULT — a Blender add-on for batch UV layer management.
This add-on was developed with the help of AI assistant.
depsgraph handler completely removed
The add‑on no longer uses any depsgraph callbacks.
Sync Render with Active UV re‑implemented with a lightweight timer
The timer runs only when the option is enabled (0.1 s interval) and stops immediately when disabled. It checks the active UV layer of each selected mesh and updates the render UV layer accordingly.
Statistics improvements
Added a popover to the new Statistics panel, allowing users to individually show/hide each statistic line: Emoticons, Mesh count, Non‑Mesh count, Meshes without UV, UV Count Mismatch, UV Names Mismatch, and UV Layers Match.
Removed “Meshes with Zero UV Area” feature
The functionality did not fit the core concept of the add‑on (UV layer management, not UV data analysis).
Various improvements for better add‑on performance and user experience
( ╯° O° )╯
