Extensions
  • Home
  • Add-ons
  • Themes
  • Approval Queue
  • About
  • Upload Extension
  • Sign in
  • BLENDER.ORG
    • Download
    • What's New
    DEVELOPMENT
    • Roadmap
    LEARNING & RESOURCES
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
All Add-ons
Add-on Unity Style Walk Navigation
Unity-style right-click first-person walk navigation.
Add-on by 時の勇者
About What's New Reviews Version History
Version: 1.1.2
License: GNU General Public License v3.0 or later (GPL-3.0-or-later)
Author: TokinoyuushaLink
Blender: 4.2+
Overview
A Unity Editor-style first-person walk navigation for the Blender 3D Viewport, replacing the built-in Walk mode.
  • Enter navigation by holding right-click and moving the mouse; release to exit (with inertia coasting)
  • Exponential smoothing for movement inertia — natural feel for acceleration, braking, and turning
  • Scroll wheel adjusts movement speed in real-time; the value is saved automatically
  • Trackpad support (Mac / Windows): two-finger swipe to control the view
  • All parameters are stored in global addon preferences (not per .blend file)
  • UI language follows Blender's interface language setting (Chinese / English)
Installation
Blender 4.2+ (Recommended)
Install as an Extension (the zip includes blender_manifest.toml):
Edit > Preferences > Add-ons > Install from Disk, select the zip file.
Legacy Format
To use by placing directly in scripts/addons: remove blender_manifest.toml from the zip, extract the folder to your addons directory, restart Blender, and enable the addon from Add-ons preferences.
Usage
Mouse Users
Input Action
RMB + Move Mouse Enter first-person navigation
Release RMB Exit navigation (with inertia coasting)
RMB during coasting Re-enter navigation
W / S / A / D / Q / E Move Forward / Backward / Left /Right / Up Down
Shift Sprint
Alt Slow / Precise movement
Scroll Up / Down Adjust movement speed
ESC Force exit navigation
Trackpad Users
In Edit > Preferences > Keymap, search for Unity Style Walk Navigation (Trackpad) and enable it.
Input Action
Two-finger swipe Enter navigation and control view
Single-finger move Trigger exit with coasting
Stop swiping (timeout) Trigger exit with coasting
Two-finger swipe during coasting Resume navigation
WASD during coasting Cancel coasting, resume navigation
Ctrl (Win) / Option (Mac) + swipe up/down Adjust movement speed
Shift Sprint
Alt (Win) / Command (Mac) Slow
ESC Force exit immediately
Parameters
Note: Hover tips (tooltips) in Blender do not support translation via the addon translation API. All tooltips are displayed in Chinese regardless of interface language. This is a Blender platform limitation shared by all addons.
N Panel (View tab)
Parameter Description
Speed Target movement speed (units/sec). The scroll wheel adjusts this in real-time and saves automatically. Shift/Alt/Command apply temporary multipliers without changing this value.
Scroll Step Speed scaling per scroll tick (default 1.15 = ±15%). Multiplicative: scroll up × value, scroll down ÷ value.
Mouse Sensitivity View rotation per pixel of mouse movement (radians). Higher = faster rotation.
Accel/Brake Feel Exponential decay smoothing: factor = 1 - e^(-value × dt). Higher = snappier; lower = more drift.
Trackpad Sensitivity View rotation per pixel of two-finger swipe. Independent from mouse sensitivity.
Trackpad Speed Step Speed scaling per trigger when using modifier+swipe. Same as Scroll Step but triggered every 20px of accumulated swipe distance.
AddonPreferences (Global Settings)
Expand the addon entry in Add-ons to access:
  • Allow Trackpad Mode: Enable trackpad navigation globally
  • Quick reference keymap table (platform-specific: Mac or Windows)
  • Reset Parameters: Restore all parameters to defaults
The collapsible section in the N panel exposes additional parameters:
Sprint Multiplier Temporary speed multiplier while holding Shift. Applied on top of target speed.
Slow Multiplier Temporary speed multiplier while holding Alt (Win) or Command (Mac). Overrides Sprint.
Min / Max Speed Clamp range for scroll wheel speed adjustment.
Cursor Style Cursor appearance during navigation: Hidden, Scroll XY, Crosshair, or Dot.
Edge Margin (px) Pixels from viewport edge to trigger cursor teleport to opposite side. Set 0 to disable.
Stop Threshold Coasting ends when speed drops below this value (units/sec).
Max Duration (s) Hard time limit for coasting to prevent infinite drift.
Known Issues
Trackpad triggers navigation in N panel
Swiping outside the 3D Viewport (Properties, Outliner, etc.) no longer triggers navigation. However, the N panel (sidebar) may still accidentally trigger navigation. This is due to a Blender API limitation: TRACKPADPAN events cannot distinguish between the main 3D viewport area and the N panel sidebar. No workaround is currently available.
Windows trackpad: coasting cannot be interrupted by swiping
On Windows, two-finger swiping during inertia coasting does not resume navigation — you must wait for coasting to finish first. This does not occur on macOS. The cause is likely a difference in how TRACKPADPAN events are delivered between platforms.
Mac trackpad: inertia interrupted by keyboard input
On Mac, the system-level trackpad momentum (TRACKPADPAN trailing events) is interrupted when a keyboard key is pressed, causing the view to stop abruptly.
Blender 4.5 + Vulkan stuttering (Windows)
Using Blender 4.5.x with the Vulkan rendering backend on Windows may cause noticeable stuttering during navigation. Switching to the OpenGL backend, or using Blender 4.2.x, is recommended.
Platform Support
Platform Mouse Navigation Trackpad Navigation
Windows + Blender 4.2 (OpenGL) ✅ Works well ⚠️ Functional, coasting cannot be interrupted
Windows + Blender 4.5 (Vulkan) ⚠️ Stuttering ⚠️ Stuttering, coasting cannot be interrupted
macOS + Blender 4.2+ ✅ Works well ✅ Works well
License
See https://www.gnu.org/licenses/gpl-3.0.html for the full license text.
What's New
1.2.0 July 7th, 2026
1.2.0
  • Fixed right-click context menu working correctly in all edit modes (Object, Mesh, Armature, Sculpt, etc.)
  • Used head=True keymap registration to ensure the addon intercepts right-click events first, without disabling native keymaps
  • Added Camera view navigation: holding RMB in Camera view moves the camera object itself; camera view is preserved on exit
  • Context menu now uses a timer-deferred popup to avoid conflicts between the modal operator and the menu
Permissions
Developer
時の勇者
Rating
Leave a review
Version
1.2.0
Updated
1 w
Published
July 2nd, 2026
Downloads
143
Size
22.9 KB
Blender 4.2 LTS and newer
Report Issues
github.com/TokinoyuushaLink/Unity-Style-Navigation-for-blender
License
3D View User Interface
...or download and Install from Disk
  • 22.9 KB
Reviews
See all
Be the first to review.
  • About
  • Terms of Service
About
  • Blender Foundation
  • Blender Institute
  • License
  • Logo & Trademark
  • Credits
  • Code of Conduct
Organization
  • People
  • Jobs
Blender Network
Download
  • Latest Blender
  • Blender LTS
  • Previous Versions
  • Experimental Builds
  • Source Code
  • Requirements
  • Benchmark
  • Flamenco
Extensions
  • Add-ons
  • Themes
Developers
  • Get Started
  • Roadmap
  • Docs
  • Forum
  • YouTube
  • Python API
  • Tools & Pipeline
Support
  • Community
  • FAQ
Get Involved
  • Education
News
  • Press Releases
  • User Stories
Blender Conference
Follow Blender
Support Blender
  • Donate
  • One-time Donation
