Turntable Camera adds a new camera panel that automatically generates key-frame sequences of turntable animation whose parameters can be rapidly refined.
Built for the purposed of model demonstration, spritesheet and flipbook creation, and website product gallery/carousel rendering.
Root Empty: If enabled, a new empty will be created as the parent of the camera. A parent object is required to move a turntable camera away from the origin.
Start: Frame at which to start the turntable
Range to Scene: If enabled, scene render range will be updated to match the turntable animation duration
Steps: Number of steps in turntable rotation.
Custom Range: Use custom start and end angles for the turntable rotation.
Offset: Constant offset angle to apply to turntable rotation.
Hold Frames: Hold each camera position for this many frames. Useful when creating turntables of animated content such as flipbooks or multiangle sprite animations.
Distance: Constant Camera distance
Shift: Constant XY Shift
Updated to support Blender 5.0
this is the best easy add-on for procedural turntables, i used to have to set up templates and change my default blend file to have a turntable scene this makes previews a breeze. for a free add-on this thing is short, sweet, predictable. the dev is also responsive to feedback and it was nice to see!
Add 360-degree camera animation in just one step
