Extensions
  • Home
  • Add-ons
  • Themes
  • Approval Queue
  • About
  • Upload Extension
  • Sign in
  • BLENDER.ORG
    • Download
    • What's New
    DEVELOPMENT
    • Roadmap
    LEARNING & RESOURCES
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
All Add-ons
Add-on Theme Updater
Theme Updater
Update themes from 4.5 LTS to 5.0.
Add-on by Community
About Reviews Version History
Utility add-on mainly for theme extension maintainers.
Blender 5.0 greatly simplified theming by generalizing common properties that were previously per-editor, such as sidebars, panels, curves, etc. Those new, generalized properties will have default colors in custom themes, which is why theme maintainers need to update their themes and assign correct values to them.
This add-on introduces an operator (in add-on preferences) that will update themes to 5.0 changes. It does it by reading the XML file of the 4.5 LTS theme and fetching colors from similar properties.
While this will work in some simple cases, it is not a foolproof method. The operator makes some assumptions about which 4.5 LTS theme properties are similar to 5.0, which might be wrong. For example, for new generalized "Panel" colors, the operator will get the panel colors from the Properties editor of the 4.5 LTS theme, which might not be correct for your theme.
After using the tool, it is always recommended to check how everything looks and, if needed, do a little bit of manual work to make sure the theme is updated correctly
How to Use:
  • Make the theme you want to update active.
  • Go to add-on preferences and click "Update Theme to 5.0" button.
  • If you see any errors, please report them as bugs. If you don't, take time to make sure theme looks correct. Check the theme migration guide and release notes to see what needs your attention.
  • Once you're happy with the theme save it from the "Theme" tab of the preferences, as usual.
Note: If you have already overwritten theme in 5.0 this tool will not work. It expects XML file saved in 4.5 LTS or earlier Blender versions. If you have overwritten it, you can either change the mode to "Custom File" and manually choose the XML file from the older version, or you can copy-paste theme file in your config from 4.5 directory to 5.0.
What's New
No changelog for this release.
Permissions
Team
Community
Rating
(8)
Version
1.0.0
Updated
9 mo
Published
Sept. 25th, 2025
Downloads
3966
Size
4.9 KB
Blender 5.0 and newer
Report Issues
projects.blender.org/nickberckley/theme_updater/issues
License
GNU General Public License v3.0 or later
System
...or download and Install from Disk
  • 4.9 KB
Reviews
See all
  • Chris-51
  • v1.0.0
  • 5 mo
Worked very well
  • warren-t
  • v1.0.0
  • 7 mo
thank you
  • thecartoonist
  • v1.0.0
  • 7 mo
IT WORKED!!!
5.0
8 reviews
5
4
3
2
1
Rate this Add-on Report an issue
  • About
  • Terms of Service
About
  • Blender Foundation
  • Blender Institute
  • License
  • Logo & Trademark
  • Credits
  • Code of Conduct
Organization
  • People
  • Jobs
Blender Network
Download
  • Latest Blender
  • Blender LTS
  • Previous Versions
  • Experimental Builds
  • Source Code
  • Requirements
  • Benchmark
  • Flamenco
Extensions
  • Add-ons
  • Themes
Developers
  • Get Started
  • Roadmap
  • Docs
  • Forum
  • YouTube
  • Python API
  • Tools & Pipeline
Support
  • Community
  • FAQ
Get Involved
  • Education
News
  • Press Releases
  • User Stories
Blender Conference
Follow Blender
Support Blender
  • Donate
  • One-time Donation
