Extensions
  • Home
  • Add-ons
  • Themes
  • Approval Queue
  • About
  • Upload Extension
  • Sign in
  • BLENDER.ORG
    • Download
    • What's New
    LEARNING & RESOURCES
    DEVELOPMENT
    • Developers Blog
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
All Add-ons
Add-on Spreadsheet Import
Spreadsheet Import
Import data to spreadsheet for use with geometry nodes.
Add-on by smonbrogg
About Permissions Reviews Version History
imported data in blender spreadsheet
New CSV Importer by Jan-Hendrik Müller
There's a new and improved CSV Importer: https://extensions.blender.org/add-ons/csv-importer/
Blender Spreadsheet Import
Import CSV or JSON data into blender spreadsheet.
The data can then be processed with geometry nodes to be visualized.
Usage
  1. Open the importer in Blender via File / Import / Spreadsheet Importer
  2. Use the filebrowser to choose a .csv or .json file
  3. Add the field names to be imported by clicking the + icon to the right of the list
  4. Type in the field names and choose their data types
    • When importing CSV, the field names must be present in the header row of the csv. The header row is a line that names the columns
    • When importing JSON, the field names must be present in the objects within the data array.
  5. When importing JSON, specify the array name where the data is in your JSON File. It must be in the root JSON object, and it must contain an array.
  6. When importing CSV, check if the delimiter is correct
  7. When importing CSV with lines before the header row, discard these by setting the Discard leading lines value
  8. Press the Import Spreadsheet button in the bottom right. The Importer will create a new Object named after the imported file. The Object wil have Mesh Data attached to it called csv_data or json_data depending on the imported file type.
  9. Check the Spreadsheet viewer in Blender to see if the data has been imported correctly.
Example Node Setup
To use the imported data in any geometry nodes tree, add an Object Info node and select the object containing the imported data in the object field.
If later you want to replace the data, you can do this in the object data properties of the selected object: Link another mesh data block to the object, and the values will update. If used column names still exist in the newly linked data block, everything should update as expected.
Sample a single value
Node setup to sample a value
Bar chart
A single float value named "field_name" is used to scale some cubes.
The Domain Size node is used to find the amounts of bars needed (the size of the imported dataset), and a duplicate of the bar geometry is created for each row of data. The duplicates are then ofset along the X axis according to the duplicate index, and scaled along the Z axis according to the data sampled from the "field_name" comumn where the row matches the duplicate index.
Node setup for a bar chart
Bar chart
Example import settings
Sample CSV Import settings
Example import options for a CSV file
Sample CSV Data:
"T 08.02.01.01.01";;;;;;;;
"Endenergieverbrauch nach Energieträger";;;;;;;;
"Tausend Terajoules";;;;;;;;
;"Total";"Brennstoffe";"Treibstoffe";"Elektrizität";"Gas";"Kohle";"Holz und Holzkohle";"Übrige Energieträger"
"2010";"905.17";"190.41";"295.08";"215.23";"115.94";"6.21";"40.93";"41.37"
"2011";"844.34";"150.85";"296.59";"210.96";"104.21";"5.74";"35.62";"40.37"
"2012";"875.82";"161.13";"299.85";"212.3";"114.32";"5.17";"39.44";"43.61"
"2013";"897.88";"168.46";"299.77";"213.56";"120.79";"5.57";"43.46";"46.27"
"2014";"827.99";"127.55";"298.26";"206.88";"107.13";"5.7";"36.73";"45.74"
"2015";"840.71";"133.89";"290.53";"209.69";"112.93";"5.21";"39.15";"49.31"
"2016";"856.43";"136.35";"291.82";"209.66";"117.24";"4.79";"42.32";"54.25"
"2017";"852.26";"127.93";"290.1";"210.54";"118.91";"4.61";"42.72";"57.45"
"2018";"833.25";"115.63";"294.3";"207.53";"112.31";"4.29";"40.45";"58.74"
"2019";"836.23";"112.31";"294.36";"205.91";"115.21";"3.81";"41.08";"63.55"
"2020";"747.9";"101.11";"226.72";"200.57";"112.9";"3.66";"39.86";"63.08"
"2021";"794.72";"111.71";"233.21";"209.21";"122.28";"3.7";"46.39";"68.22"
"Letzte Änderung:  27.07.2022";;;;;;;;
"Quelle: BFE � Gesamtenergiestatistik";;;;;;;;
"� BFS 2022";;;;;;;;
The imported Data viewed in the spreadsheet editor:
Imported data viewed in blender spreadsheet
What's New
No changelog for this release.
Permissions
This extension requests the following permission:
  • Files
    Load CSV and JSON files from disk
Developer
smonbrogg
Rating
(1)
Version
0.4.0
Updated
8 mo
Published
Oct. 10th, 2024
Downloads
5803
Size
16.2 KB
Blender 4.2  and newer
Report Issues
github.com/simonbroggi/blender_spreadsheet_import/issues
License
GNU General Public License v3.0 or later
Import-Export Geometry Nodes
...or download and Install from Disk
  • 16.2 KB
Reviews
See all
  • Louis_v_a
  • v0.4.0
  • 4 mo
Fantastic add-on! For me an efficient way to import cad data (objects) into blender. Thanks for the good work!
5.0
1 review
5
4
3
2
1
Rate this Add-on
  • About
  • Terms of Service
Download
  • Latest Blender
  • Blender LTS
  • Blender Benchmark
  • Previous Versions
  • Experimental Builds
  • Source Code
  • Release Notes
  • Requirements
Organization
  • People
  • Jobs
About
  • Blender Foundation
  • Blender Institute
  • License
  • Logo & Trademark
  • Credits
Articles
  • News
  • Press Releases
  • User Stories
Get Involved
  • Dashboard
  • Development
  • Education
Support
  • Community
  • FAQ
Developers
  • Get Started
  • Docs
  • Forum
  • YouTube
  • Python API
Blender Conference
Follow Blender
Support Blender
  • Donate
  • One-time Donation
