Sculpt Pose Sync is a practical workflow add-on designed to simplify the process of symmetrically sculpting rigged and posed models.
Normally, when you need to sculpt symmetrically on a posed character, you have to reset the armature to its rest pose (T-Pose or A-Pose). However, doing so makes it impossible to see how the muscles or clothes actually deform in the final pose. This add-on solves that pain point natively: it automates a dual-mesh setup, allowing you to sculpt symmetrically on the rest pose while effortlessly previewing the posed result side-by-side, completely eliminating complex manual setups.
姿态对称雕刻同步 (Sculpt Pose Sync) 是一款致力于简化“带骨骼姿态模型雕刻”工作流的实用插件。
在正常情况下,当我们想要对已经摆好姿势的模型进行对称雕刻时,必须先将骨骼重置回静止位置(T-Pose 或 A-Pose),但这会导致我们无法直观地看到模型在特定姿态下(如肌肉拉伸、布料褶皱)的形变效果。 本插件完美解决了这个痛点:它能帮你自动搭建一个同步工作流,让你在一边对无姿态的模型进行对称雕刻的同时,另一边能直观、实时地预览模型摆出姿势后的样子,彻底告别繁琐的手动设置。
One-Click Sculpt Workspace: Select a posed mesh, and the add-on automatically splits your screen (or opens a new window). It isolates a clean, un-posed model for distraction-free sculpting on one side, while keeping the posed preview on the other.
Smart Multires & Subdivision Sync: It automatically prepares the Multiresolution modifiers. When you need more detail, a single click on the panel safely increases the subdivision levels for both the sculpt and pose models simultaneously to prevent topology mismatch.
Pure Manual Detail Syncing: To guarantee maximum viewport performance and zero background lag, the add-on uses a strict manual sync approach. Whenever you want to evaluate your posed result, simply hit "Force Sync Details" to instantly project your sculpted forms onto the posed model.
Safe Disconnect & Archiving: When finished, safely unlink the models. Your sculpt mesh isn't deleted; instead, it gets timestamped, hidden, and archived as a historical backup. You can easily clone and restore any previous version directly from the panel if needed.
一键搭建雕刻工作区: 选中带姿势的模型后,插件会自动为你分割当前视图(或弹出一个新窗口)。一边显示姿态预览,另一边为你隔离出干净的静止模型供你专注雕刻,两者互不干扰。
智能添加与同步细分: 插件会自动为模型配置好“多级精度 (Multires)”修改器。需要增加细节时,只需在面板上点击一次,即可双向同步提升雕刻模型和姿态模型的细分等级,避免手动调整导致拓扑崩溃。
纯净手动细节同步: 为保证 Blender 视口能够跑出最高帧率,插件采用零后台监听的纯净设计。雕刻过程中,当你需要查看最终姿态效果时,只需点击“一键手动同步细节”,即可瞬间将笔刷形变投射到姿态模型上,真正做到性能与效果兼得。
安全断开与历史备份: 雕刻完成后,可以安全地断开两者连接。插件不会直接删除你的静止模型,而是将其加上时间戳,自动隐藏并封存为“历史备份”。未来如果需要修改,随时可以从面板里一键克隆恢复。
