Extensions
  • Home
  • Add-ons
  • Themes
  • Approval Queue
  • About
  • Upload Extension
  • Sign in
  • BLENDER.ORG
    • Download
    • What's New
    LEARNING & RESOURCES
    DEVELOPMENT
    • Developers Blog
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
All Add-ons
Add-on Scene Workspaces
Scene Workspaces
Filter and sort your workspaces, scene by scene.
Add-on by Francesco-Bellini
About What's New Reviews Version History
Overview
Scene Workspaces creates an alternative workspaces topbar, allowing you to filter and reorder workspaces, scene by scene.
Basically, you can decide which workspace you want to link to each scene.
Scene Workspaces can be particularly useful in projects with multiple scenes with different needs/purpose.
Scene Workspaces is based on simple custom properties at scene level.
Make yourself comfortable
You can customize Scene Workspaces from add-on preferences:
  • Show only with multiple scenes (default: off)
    Show the topbar (and eventually the checkbox) only when the project has multiple scenes.
    Basically, Scene Workspaces disappear as long as you have one scene only.
  • Auto initialize Scene Workspaces (default: on)
    Automatically add all available workspaces to the current scene, if empty.
    If available workspaces match one of the 5 default templates, they will be automatically ordered on initialization. Otherwise, workspaces will be ordered alphabetically.
  • Show Checkbox (default: on)
    When active, shows a checkbox to switch between Scene Workspaces and the default topbar.
    This checkbox will directly affect the next preference.
  • Use Scene Workspaces topbar (default: on)
    Switch between Scene Workspaces topbar and the default topbar.
  • Use Compact Mode (default: on)
    Also avaliable from the workspace menu.
    Compact Mode ON
    Compact Mode On
    Compact Mode OFF
    Compact Mode Off
Topbar menus
What you can usually to do by right-clicking on a workspace (and more) it's avaliable by clicking the near options button.
The first options are the ones from Scene Workspaces:
  • Toggle Compact Mode (preference)
  • Unlink workspace from scene
  • Rename (for all scenes)
  • Reorder to front (only for this scene)
  • Move left (only for this scene)
  • Move right (only for this scene)
  • Reorder to back (only for this scene)
  • Previous workspace (using scene order) Shift + Ctrl + Page Up
  • Next Workspace (using scene order) Shift + Ctrl + Page Down
Note
Default options like Reorder to Front, Reorder to Back will only affect the global workspaces, and not the Scene Workspaces topbar.
Instead, use the ones marked with (scene only) or use the panel instead.
Also, default options Previous Workspace and Next Workspace will follow the global workspaces order, and not the scene order.
Instead, use the ones marked with (scene) or the relative shortcuts (default ones + Shift).
You can link other workspaces to the current scene, using the menu with the workspace icon:
Link other workspaces
or by clicking the active workspace, if it's not currently linked
Link current
You can also copy the linked workspaces from another scene, using the menu with the duplicate icon:
Copy from scene
Panel Management
You can always reorder, rename, link and unlink the Scene Workspaces, using the panel Properties > Scene > Scene Workspaces.
At the top, you can select and reorder, rename or unlink any workspace.
At the bottom, you can link the missing workspaces to the current scene.
Scene Workspaces Panel
Templates
You can use the add-on Custom Templates to prepare templates with your Scene Workspaces already configured.
Why this add-on?
In Blender, workspaces are common across scenes.
At the same time, you may need different workspaces in different scenes, depending on the purpose of the scene.
For example, you may want a scene with workspaces optimized for modelling and another Scene optimized for Video Editing, in the same project.
Scene Workspaces make this possible with the custom topbar and a custom property for each scene.
For more info, checkout the project's README.
What's New
1.1.1 September 14th, 2024
  • Auto initialize Scene Workspaces if empty (on load, on scene change)
  • Auto order Scene Workspaces, on initialization
    Only when using workspaces from one of the 5 default Blender's templates
  • Update Properties > Scene > Scene Workspaces panel
    Rename, unlink and reorder buttons are now based on the active element, for better UX.
  • New preferences:
    1. Show only with multiple scenes (default: false)
      Show the custom topbar and the checkbox (if enabled) only if the project has multiple scenes. Basically, Scene Workspaces disappear as long as you have one scene only.
    2. Auto initialize Scene Workspaces (default: true)
      When active, automatically initialize (and for common cases, order) Scene Workspaces when empty (on load, on scene change). All avaliable workspaces are added.
  • Fix partial select all
Permissions
Developer
Francesco-Bellini
Rating
Leave a review
Version
1.1.1
Updated
9 mo
Published
Sept. 8th, 2024
Downloads
4356
Size
8.6 KB
Blender 4.2  and newer
Website
projects.blender.org/Francesco-Bellini/scene_workspaces_addon
Report Issues
projects.blender.org/Francesco-Bellini/scene_workspaces_addon/issues
License
GNU General Public License v3.0 or later
Scene System User Interface
...or download and Install from Disk
  • 8.6 KB
Reviews
See all
Be the first to review.
  • About
  • Terms of Service
Download
  • Latest Blender
  • Blender LTS
  • Blender Benchmark
  • Previous Versions
  • Experimental Builds
  • Source Code
  • Release Notes
  • Requirements
Organization
  • People
  • Jobs
About
  • Blender Foundation
  • Blender Institute
  • License
  • Logo & Trademark
  • Credits
Articles
  • News
  • Press Releases
  • User Stories
Get Involved
  • Dashboard
  • Development
  • Education
Support
  • Community
  • FAQ
Developers
  • Get Started
  • Docs
  • Forum
  • YouTube
  • Python API
Blender Conference
Follow Blender
Support Blender
  • Donate
  • One-time Donation
