Lets you select subcollections in your scenetree, then for each subcollection: Activates it, renders the camera(s) inside and deactivates it again.
Naming is totaly up to you, just make sure to select your Main Collection in the panel, then your Subcollections should be listed for you to check which one should be rendered.
Removed 3D View and Pipeline tags.
