Extensions
  • Home
  • Add-ons
  • Themes
  • Approval Queue
  • About
  • Upload Extension
  • Sign in
  • BLENDER.ORG
    • Download
    • What's New
    DEVELOPMENT
    • Roadmap
    LEARNING & RESOURCES
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
All Add-ons
Add-on Quick Asset Manager
Quick Asset Manager
Quickly Create, Edit, Organize, or Delete your local asset files.
Add-on by Clonephaze
About What's New Permissions Reviews Version History
Quick Asset Saver Preview (Currently outdated, replacing soon) Quick Asset Bundler Preview
Blender's Asset Library is powerful, but managing your own assets is unnecessarily tedious. Saving assets takes too many steps, and once they're saved, Blender offers no easy way to rename, edit metadata, reorganize catalogs, or delete assets without manually opening files.
Quick Asset Manager fixes that.
It lets you save assets directly to your configured libraries with full metadata support, then manage those assets in place. Rename them, edit metadata and tags, move them between catalogs or libraries, swap them into scenes, or delete them entirely. No file hunting. No opening .blend files just to make a small change.
Requires Blender 4.2 or newer.
Features
  • Direct Save: Save selected assets to any configured Blender library with one click, including optional catalog assignment and automatic dependency packing (images, fonts, sounds, movie clips).
  • Copy Catalog from Current File: Reuse an asset's existing catalog when saving — if it doesn't exist yet in the target library, it's created automatically.
  • Editable Saved Assets: Edit any metadata fields or tags on assets you've already saved, right from the Asset Browser sidebar.
  • Move & Organize: Move assets between catalogs or entire libraries without touching the filesystem. Choose how conflicts are handled — increment the filename, overwrite, or skip.
  • Swap Assets: Replace selected scene objects by right-clicking any object or collection asset.
  • Delete Assets: Remove assets straight from the Asset Browser. Files (and their thumbnails/companion folders) go to your system's recycle bin, not permanent deletion.
  • Bulk Operations: Select multiple assets — in a library or directly in your Current File — to Move or Bundle them all at once.
  • Bundling: Package selected assets into a single, shareable .blend file, with automatic duplicate handling and optional catalog file copying.
Usage
Saving Assets
  1. Open the Asset Browser and switch to Current File view
  2. Select an asset you want to save
  3. Open your tool panel (N by default)
  4. Configure the asset name, catalog, and metadata as needed (or enable Copy Catalog from Current File to reuse its existing catalog)
  5. Choose your target library from the dropdown
  6. Click Copy to Asset Library
Editing Assets
  1. Open the Asset Browser and select any already saved asset
  2. Open your tool panel (N by default)
  3. Click Edit Metadata/Tags, make your changes, then click Apply Changes
Moving Assets
  1. Open the Asset Browser and select one or more already saved assets
  3. Choose a new library and/or catalog destination, and how to handle filename conflicts (Increment, Overwrite, or Skip)
  4. Click Move Asset (or Move N Assets for a multi-selection)
Deleting Assets
  1. Open the Asset Browser and select an already saved asset
  2. Open your tool panel (N by default) and click Remove Asset from Library, or right-click the asset and choose Remove Asset from Library
  3. The asset's file and any companion thumbnails/folders are sent to your system's recycle bin
Swapping Assets
  1. Ensure an item is selected in your scene
  2. Open the Asset Browser and find any already saved asset
  3. Right-click your desired asset and choose Replace Selected Objects
(Note: Only works for collection and object assets)
Bundling Assets
  1. Select two or more assets — either in a configured library, or directly in your Current File
  2. Continue from the Bulk Operations panel in the sidebar
  3. Set a bundle name and target save directory
  4. Configure duplicate handling and whether to copy the catalog file
  5. Click Bundle N Assets and wait for it to complete
    The addon will:
    • Create a bundled .blend file with all your selected assets
    • Automatically pack all required images and dependencies
    • Apply all metadata and catalog assignments
    • Save to your chosen directory with proper file naming
    • Optionally save a copy of your catalog (categories) file
Bulk Moving from Current File
Selecting two or more unsaved assets in your Current File view brings up the same Bulk Operations panel, letting you Move or Bundle them straight to a library without saving them one at a time first.
Preferences
Configure these under Edit > Preferences > Add-ons > Quick Asset Manager:
  • Default Asset Library: The library pre-selected when saving new assets.
  • Organize by Catalog: Automatically create subfolders matching your catalog structure (e.g. Materials/Metal).
  • Filename Conventions: Optional prefix, suffix, and date stamp applied to every saved asset's filename.
  • Default Metadata: Default author, description, license, and copyright applied to new assets.
  • Auto-Refresh Asset Browser: Automatically refresh the Asset Browser after saving.
  • Max Bundle Size: Safety limit (in MB) to warn before importing too many assets into one bundle.
Support me
If you would like to help fund development, or just give me a tip, I have a Buy me a Coffee page here
What's New
2.1.1 July 5th, 2026
Minor Release - Small bug fixes
  • includes some last minute fixes for a couple of issues that I had forgot to bundle with the last release.
See all versions
Permissions
This extension requests the following permission:
  • Files
    To read and write to asset library directories
Developer
Clonephaze
Rating
(5)
Version
2.1.1
Updated
2 w
Published
Oct. 30th, 2025
Downloads
7566
Size
78.4 KB
Blender 4.2 LTS and newer
Website
clonecore.net
Report Issues
github.com/Clonephaze/QuickAssetSaver/issues
License
GNU General Public License v3.0 or later
System User Interface
...or download and Install from Disk
  • 78.4 KB
Reviews
See all
  • creative-devil
  • v2.0.3
  • 4 mo
Life saver here! I spent the last few days trying to set up libraries and such.... I wish Blender would make a cleaner format. Thank you gracious creative!
  • Clonephaze replied
  • 4 mo
Thank you so much for the review, I'm glad you've found the add-on useful!
  • zualia-zualia
  • v2.0.0
  • 6 mo
"This plugin is very useful. However, in a Chinese language environment, the Resource Mover fails to display the asset directory, making it impossible to move assets. Could you please optimize this?"
  • 6 mo
Hello! I have pushed a fix to the move panel so it should now display Character-Based languages such as Chinese, Japanese, Korean, etc. as the other menus do. Thank you for pointing it out, and for the review! Both are always appreciated.
  • Ibra-5
  • v1.3.1
  • 6 mo
Very good!
  • 6 mo
Thank you so much! I really appreciate it.
5.0
5 reviews
5
4
3
2
1
Rate this Add-on Report an issue
  • About
  • Terms of Service
About
  • Blender Foundation
  • Blender Institute
  • License
  • Logo & Trademark
  • Credits
  • Code of Conduct
Organization
  • People
  • Jobs
Blender Network
Download
  • Latest Blender
  • Blender LTS
  • Previous Versions
  • Experimental Builds
  • Source Code
  • Requirements
  • Benchmark
  • Flamenco
Extensions
  • Add-ons
  • Themes
Developers
  • Get Started
  • Roadmap
  • Docs
  • Forum
  • YouTube
  • Python API
  • Tools & Pipeline
Support
  • Community
  • FAQ
Get Involved
  • Education
News
  • Press Releases
  • User Stories
Blender Conference
Follow Blender
Support Blender
  • Donate
  • One-time Donation
