More friendly alignment based on observation perspective
(Align objects (XYZ coordinates) like using Photoshop or PowerPoint in Blender)
· Perspective based position/rotation/scaling alignment
· Distribution 1:Uniformly distributed according to the origin or spacing of each object
·Distribution 2:According to the uniform distribution of objects at the beginning and end, the object in the middle
·Align the ground:Support aligning multiple objects individually to the ground or as a whole to the ground
·Fall:Global Z-ray projection, causing objects to fall onto other objects, simulating non physical drops
·General: Align to world origin, active, cursor.
When using the functions of aligning to the world origin, active, and cursor.
Ctrl+click: Align Rotate
Shift+Click: Align Scale
Alt+Click: Align Position
Can be used in combination
If you encounter any problems or have any good ideas, you can leave a message on our Discord channel.
https://blenderartists.org/t/free-add-on-blender-popoti-alignment-helper/
Fix: Bforartists 4.4.0 translate
Feat: add operator description
Good and useful addon (there are only korean version or english too?
It supports both Chinese and English and automatically switches based on the system language settings
Excelent Addon
Awesome
