Extensions
  • Home
  • Add-ons
  • Themes
  • Approval Queue
  • About
  • Upload Extension
  • Sign in
  • BLENDER.ORG
    • Download
    • What's New
    LEARNING & RESOURCES
    DEVELOPMENT
    • Developers Blog
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
All Add-ons
Add-on Node Quick Maths
Node Quick Maths
A fast way to make long math chains in node editors.
Add-on by Zeptofine
About What's New Reviews Version History
Video of it in action
Trivially make long math chains using a simple Python expression.
Check the Math Formula extension out! It supports all of the same features, and much, much more.
https://extensions.blender.org/add-ons/math-formula/
This supports the main builtin node editors in blender: Shader Editor, Geometry Node Editor, Texture Node Editor, Compositor
Usage
Default Keyboard Shortcut - Ctrl + M
In the text box that appears, type in a mathematical expression that you want to evaluate, for example, sin(x + 64) % (y ** 14 + 10). Accept the dialogue and a node tree will be generated with math nodes.
Mathematical operators you would expect to work are supported, including:
  • Addition, Subtraction, Multiplication, Division, Power: + - * / **
  • Less Than, Greater Than: < >
  • Modulo: %
And all other mathematical functions in the Math node is supported.
  • Logarithm: log(x[, base])
  • Square Root: sqrt(x)
  • Abs: abs(x)
  • Exponential: exp(x)
Comparison
  • Min: min(x, y)
  • Max: max(x, y)
  • Compare: cmp(x, y, z)
  • Smooth Min: smin(x, y, z)
  • Smooth Max: smax(x, y, z)
Rounding
  • Round: round(x)
  • Floor: floor(x)
  • Ceil: ceil(x)
  • Truncate: trunc(x) or int(x)
  • Fraction: frac(x)
  • Floored Modulo: fmod(x, y)
  • Wrap: wrap(x, y, z)
  • Snap: snap(x, y)
  • Ping-Pong: pingpong(x, y)
Trig
  • Sin: sin(x)
  • Cos: cos(x)
  • Tan: tan(x)
  • Arcsine: asin(x)
  • Arccosine: acos(x)
  • Arctangent: atan(x)
  • Arctan2: atan2(x)
  • Hyperbolic Sine: sinh(x)
  • Hyperbolic Cosine: cosh(x)
  • Hyperbolic Tangent: tanh(x)
Conversion
  • To Radians: rad(degx)
  • To Degrees: deg(radx)
What's New
1.2.2 July 29th, 2024
Edit preferences lookups as per guidelines
See all versions
Permissions
Developer
Zeptofine
Rating
(12)
Version
1.2.2
Updated
10 mo
Published
June 27th, 2024
Downloads
16366
Size
21.9 KB
Blender 4.2  and newer
Website
github.com/zeptofine/node-quick-maths
Report Issues
License
GNU General Public License v3.0 or later
Node Pipeline User Interface
...or download and Install from Disk
  • 21.9 KB
Reviews
See all
  • Pablo-P
  • v1.2.2
  • 3 mo
So useful, thanks a lot!
  • MArio-del-Barrio-Tejeda
  • v1.2.2
  • 5 mo
Muy útil
  • FuzzyExpress
  • v1.2.2
  • 5 mo
This is exactly what I needed, and it works perfectly!
Also I have a suggestion: add support for adding drivers like #frame or #bpy.data.scenes["Scene"].frame_start / end. It could be done using [], {} or #(). (or something else.) Example: https://imgur.com/a/xVvxAWK
5.0
12 reviews
5
4
3
2
1
Rate this Add-on
  • About
  • Terms of Service
Download
  • Latest Blender
  • Blender LTS
  • Blender Benchmark
  • Previous Versions
  • Experimental Builds
  • Source Code
  • Release Notes
  • Requirements
Organization
  • People
  • Jobs
About
  • Blender Foundation
  • Blender Institute
  • License
  • Logo & Trademark
  • Credits
Articles
  • News
  • Press Releases
  • User Stories
Get Involved
  • Dashboard
  • Development
  • Education
Support
  • Community
  • FAQ
Developers
  • Get Started
  • Docs
  • Forum
  • YouTube
  • Python API
Blender Conference
Follow Blender
Support Blender
  • Donate
  • One-time Donation
