Add a pie menu, quick buttons, and shortcuts for switching between the different node editors.
Accessible in the Node Editor, the pie menu is an easy way to switch between different node editors with a single click.
E
The Quick Access Buttons are available at the top right of the Node Editor header and can be enabled in the addon preferences.
1
: Geometry Node Editor2
: Shader Node Editor3
: World Node Editor4
: Compositor Node EditorThis extension does not require special permissions.
It works but the pie menu editor wich is already implemented can do the same
Pie menu editor is a paid add-on from what I can see, and it's not "already implemented." This add-on doesn't have the same goal. Yes, you can recreate the same pie menu with this add-on, but the main goal of this small extension is to provide an already set-up pie menu focused on the Node Editor with some extended features like a quick switch button or shortcut. If this extension doesn't work for your workflow, that's fine, but please don't compare it to a paid add-on that doesn't have the same goal.
Absolutlely wonderful addon
1-4 keys are so familiar, so it really boosts my performance
