Extensions
  • Home
  • Add-ons
  • Themes
  • Approval Queue
  • About
  • Upload Extension
  • Sign in
  • BLENDER.ORG
    • Download
    • What's New
    DEVELOPMENT
    • Roadmap
    LEARNING & RESOURCES
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
All Add-ons
Add-on NFC Card and Keychain Generator
Generate customizable 3D-printable cards, tags, and keychains.
Add-on by Clonephaze
About What's New Permissions Reviews Version History
Quick Tool Usage + Color on Export Preview Examples of what you could make with this tool Example of the new text feature The menu options
3D-Printable & Customizable Tags, Cards, & Keychains
NFC chips and QR codes are powerful tools – they can share your socials or contact card, let guests tap to join your Wi-Fi, or even trigger automations with a single scan. However on their own, NFC chips don’t look great, and a paper QR code isn’t much better.
This add-on lets you design 3D-printable housings for NFC chips. You can add your own logos or icons (Wi-Fi symbol, social media logo, etc.), or use the built-in QR generator to put a backup code directly on the surface of the print.
Main Features
  • Versatile shapes – Cards, dots, or keychains with adjustable height, bevels, rounded corners, and optional magnet slots.
  • SVG support – Import any SVG logo and turn it into an object on your housing, with the option to inset designs for flush multi-color prints.
  • QR fallback – Generate QR codes for links, vCards, Wi-Fi details, or plain text and place them like any other logo.
  • Magnet slots – Choose between hexagonal or circular cutouts, set width/height, and let the tool auto-adjust the housing height.
  • NFC optional – Disable the NFC cutout to create solid cards or keychains without cavities.
Quickstart
  1. Install and enable the add-on.
  2. Open the NFC Cards tab in the N-panel (press N in the 3D Viewport).
  3. Click Prep Scene to generate the base card and clear any interfering objects.
  4. Choose shape, dimensions, and optional NFC or magnet cutouts.
  5. Import an SVG logo or generate a QR code, adjusting scale and offsets as needed.
  6. Export your customized housing as an STL ready for printing.
Multi-Color Printing & NFC Slot Setup in Orca Slicer
  1. Import the STL into Orca.
  2. Right click the object > Split > to Parts (not to Objects).
  3. In the left panel, open the Objects tab (next to Process). You’ll see a list of numbered objects.
  4. Right click object 2 > Change Type > set to Negative Object.
  5. For objects 3 and up, right click > Change Filament Type > assign your second color.
    • Optional: If the design is inset, flip the STL 180° for a cleaner top surface.
  6. Slice and scrub the slider to the layer just before the NFC cavity gets covered. Right click > Add Pause.
  7. Re-slice and save/send g-code to your printer.
Requirements & Manual Installation
You need:
  • Blender 4.2.0 or later
Manual install:
  • Download nfcCardGen.zip.
  • Drag and drop it into Blender, then enable the extension.
  • Or go to Edit > Preferences > Add-ons > Install from Disk, select the zip, and enable it.
License
GNU GENERAL PUBLIC LICENSE Version 3, 29 June 2007
Support & Feedback
For questions, issues, or feature requests, please open an issue in the project repository or contact me at jack@clonecore.net.
Support me
If you’d like to support my Blender development (or help me replace my fried GPU 😅), you can donate here: https://buymeacoffee.com/clonephaze
What's New
1.2.3 June 30th, 2026
v1.2.3 3mf Export Option Removed
Per Blenders policy, you will now need to manually export via 3mf if you would like to export the card as a 3mf object. This was done per request and I cannot do anything about it.
See all versions
Permissions
This extension requests the following permission:
  • Files
    For custom SVG import and file saving operations
Developer
Clonephaze
Rating
Leave a review
Version
1.2.3
Updated
2 w
Published
Sept. 30th, 2025
Downloads
3216
Size
501.5 KB
Blender 4.5 LTS and newer
Website
github.com/Clonephaze/nfc-keychain-generator-blender-addon
Report Issues
github.com/Clonephaze/nfc-keychain-generator-blender-addon/issues
License
GNU General Public License v3.0 or later
Modeling Object
...or download and Install from Disk
  • 501.5 KB
Reviews
See all
Be the first to review.
  • About
  • Terms of Service
About
  • Blender Foundation
  • Blender Institute
  • License
  • Logo & Trademark
  • Credits
  • Code of Conduct
Organization
  • People
  • Jobs
Blender Network
Download
  • Latest Blender
  • Blender LTS
  • Previous Versions
  • Experimental Builds
  • Source Code
  • Requirements
  • Benchmark
  • Flamenco
Extensions
  • Add-ons
  • Themes
Developers
  • Get Started
  • Roadmap
  • Docs
  • Forum
  • YouTube
  • Python API
  • Tools & Pipeline
Support
  • Community
  • FAQ
Get Involved
  • Education
News
  • Press Releases
  • User Stories
Blender Conference
Follow Blender
Support Blender
  • Donate
  • One-time Donation
