Make screenshots in Blender, and paste them in Penpot ready-to-use with (upcoming) Blender's Design System.
How to use it
- Find the "Mockup Screenshot" operator in the Window menu.
- Drag the rectangle you want to capture.
- Paste the result in Penpot.
- The add-on creates two screenshots: one with the
Blender Dark theme, and another with the Mockup theme.
- It then combine them in a group with an Opacity design token on the dark screenshot.
- This way if you switch Themes in penpot you will see the corresponding capture.
- For an example of the Tokens in penpot see tokens.json.
Setup
- Install the Mockup theme.
- If you don't want to use the Mockup theme, you can change the theme to be used In the preferences.
Known Limitations
- Top-bar and status bar are not refreshed.
- Drawing overlay of the rectangle not working.
The code already support those limitations based on work-in-progress patches that may be ready in time for 5.1. They both sprung from missing features on Blender's Python API.
