This addon reshape jagged edge loops into smooth ones along a curve.
3D View > Sidebar > Mio3 (Can be changed in the Preferences category field)
Select the edge loop you want to edit and click "Mio3 Flex" in the sidebar → "Path Deform". If multiple edge loops are selected, an independent path is created for each one.
If you don’t use the path control options, you can instantly apply the deformation by pressing the “Quick” button.
Click on empty space / Enter / Tab: Confirm deformationDrag on empty space / Shift + click a control point: Multi-selectDrag a control point: Move the control pointG: Move selected control pointsCtrl + click on the spline: Add or remove a control pointDel: Delete selected control pointsShift + mouse wheel: Change the number of control points on the current shapeAlt + mouse wheel: Change the number of control points on the original shape↑ / ↓: Adjust curve strengthX / Y / Z: Lock the movement axisM: Toggle mirror modeR: Reset deformationH: Hide the splineESC: Cancel deformationSupports an industry compatible keymap
Thank you for this add-on! Can't live without it
It is perfect, thank you.
