Adds two new commands to the mesh editor:
Mesh > Show Attributes
Displays values for the currently selected vertex, edge or face mesh attribute as text in the 3D view (limited to 100 values to avoid crashing with large meshes).
Mesh > Batch Set Attributes
An enhanced version of Mesh > Set Attribute which allows setting multiple mesh attributes for the selection at once, instead of only the current attribute.
I've found this quite useful when using meshes with many custom attributes as inputs for geometry nodes.
And two new commands to object mode:
Object > Rename Attribute
Rename an attribute on the selected meshes, preserving data.
Object > Edit Mesh Attribute Schema
Copy attribute definitions from/to all selected meshes, or bulk-delete attributes.
Will it be updated to work with Blender 5.0? Thanks
Awesome add-on!
