Extensions
  • Home
  • Add-ons
  • Themes
  • Approval Queue
  • About
  • Upload Extension
  • Sign in
  • BLENDER.ORG
    • Download
    • What's New
    LEARNING & RESOURCES
    DEVELOPMENT
    • Developers Blog
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
All Add-ons
Add-on Key Ops: Toolkit
Key Ops: Toolkit
Industri Standard Tools & Shortcuts to Speed Up Blender Workflow.
Add-on by Dan-Gry
About What's New Permissions Reviews Version History
Features
All add-on functions can be enabled/disabled in the preferences
Industri Standard Keymaps
Alt Navigation - Navigate like in Maya (+ Tablet Navigation Mode)
Dbl-Click to Select Mesh Island
Auto Delete - Instantly delete verts,edges and faces with no menu pop up with the Delete key image
Pivot Tool - Pivot Tool D in Object/Edit Mode(exprimental) that works similar to D in Maya image
Toggle Retopology - One Click Toggle Retopology Overlay + settings and tool Image
UV Tools
  • Sharp Edges From UV Islands - Add sharp based on UV Islands to fix shading on uv unwraped meshes. With the only UV Island Borders option it will not add any sharp edges to for example an uv seam on a cylinder.
  • UV Cut - Cut an Island, works more similar to cut in Maya Shift X and X
Pie Menus
Add Objects Pie - Faster way to add Mesh Primitivs, that also is automatically scaled relatively so it's never too big/small on the screen Image
Workspace Pie - Switch Workspace Faster
Cursor Pie - Better Pie Menu on Shift S with better pivot functinality then the defualt one
Fast Merge - Merges the active/selected verts to the vert nearest mouse position with 1 Key
Connect - Connects Edges/Faces like in Maya/3ds Max ** Shift 1** image
Game Art Toolkit
CAD Decimate - Tool to decimate very high poly meshes image
Auto LOD - Tool to quickly create LODs
Quick Bake Name - Tool to quickly create bake names for high and low poly objects
Polycount List - Realtime poly-count statistics of objects in the scene with filtering options.
Toolkit Panel
Adds new Modeling and utility operations to to the Toolkit Panel image
Snap to gridfloor - Snaps the selected objects to the floor, Hold Alt - Individual, and Ctrl for Fast Mode in Object Mode, Alt 3 Snap to Floor
Duplicate Linked Modifiers - Duplicates the selected objects and creates a modifier instance that will have the linked modifiers from the original mesh. This means any changes of the original mesh will be replaced on the new duplicated mesh in real time. This is also works in Modifier List, making it even more smooth to use! Duplicate Linked Modifiers
Laggy Booleans is now optional! - Turning off Live Booloens will pause the boolean evaluation during transform until you have confirmed. Massivly helps with performance with very heavy modifier stacks and keeping everthing more interactive. image Perfomance is the best when not using gizmos to move the object, instead use G, R, S
Smart Apply Scale - Apply Scale to Objects withoute destroying the objects modifers scale, even works with Geomtry Nodes! image
Triplanar Uvs Modifier - (Box Projection UVW in 3ds Max) image Quick Export - Exports the currently selected meshes
Attributes Operations - Adds new buttons to the attributes panel, simplifies and makes it more similar to how adding/removing vertex groups works.
Viewport Meny
  • Viewport Overlays Menu for quick acces to settings + Silhouette Mode Toggle on Alt V
Outliner Options - Extra options in the outliner to make it more convenient to use image
  • Auto Select in Outliner (will focus on the object in the outliner)
  • Collapse Unselected Collections
Material Utilities
Material Index Panel - Tool to sort and assign Material Indexes after a index list. Useful for when exporting models to 3ds Max when using multi materials. image
Material List - Easy assigment of materials in Object and Edit Mode on Alt M image
Documation, Blenderartist
What's New
0.2.1985 May 10th, 2025
Fixed issue with Pivot D Tool
See all versions
Permissions
This extension requests the following permission:
  • Files
    Export/Import .obj files and use of temp folder
Developer
Dan-Gry
Rating
(25)
Version
0.2.1985
Updated
1 mo
Published
July 16th, 2024
Downloads
34084
Size
196.5 KB
Blender 4.2  and newer
Website
key-ops-toolkit.notion.site/Key-Ops-Toolkit-Documentation-8683460f070542669f0dab4a92734dc9
Report Issues
github.com/Dangry98/Key-Ops-Toolkit/issues/new
License
GNU General Public License v3.0 or later
3D View Modeling Mesh Object UV
...or download and Install from Disk
  • 196.5 KB
Reviews
See all
  • amir-63
  • v0.2.1985
  • 4 w
This is one of the must-have add-ons. Well done.
  • Stanley-1
  • v0.2.1985
  • 1 mo
Great add-on!
  • ZXSpectrum128
  • v0.2.198
  • 1 mo
Best add-on!
5.0
25 reviews
5
4
3
2
1
Rate this Add-on
  • About
  • Terms of Service
Download
  • Latest Blender
  • Blender LTS
  • Blender Benchmark
  • Previous Versions
  • Experimental Builds
  • Source Code
  • Release Notes
  • Requirements
Organization
  • People
  • Jobs
About
  • Blender Foundation
  • Blender Institute
  • License
  • Logo & Trademark
  • Credits
Articles
  • News
  • Press Releases
  • User Stories
Get Involved
  • Dashboard
  • Development
  • Education
Support
  • Community
  • FAQ
Developers
  • Get Started
  • Docs
  • Forum
  • YouTube
  • Python API
Blender Conference
Follow Blender
Support Blender
  • Donate
  • One-time Donation
