Extensions
  • Home
  • Add-ons
  • Themes
  • Approval Queue
  • About
  • Upload Extension
  • Sign in
  • BLENDER.ORG
    • Download
    • What's New
    DEVELOPMENT
    • Roadmap
    LEARNING & RESOURCES
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
All Add-ons
Add-on Bugsnax Cache Importer/Exporter
Import/Export Bugsnax .xcache, .objcache, .daecache.
Add-on by SaintBaron
About What's New Reviews Version History
Import view
io_bugsnax
A Blender addon for importing and exporting the cache formats used by Bugsnax and the Horsepower Engine — the static mesh caches (.objcache / .daecache) that ship alongside the engine's skinned characters, and the skinned-character cache (.xcache) itself.
All three share the SEMS binary magic. The static caches hold a single static mesh with up to three texture references (diffuse, normal, specular); the .xcache format additionally carries a skeleton, skin weights, and animation.
Format Kind Per-vertex / payload
.objcache Static mesh position · normal · colour · UV
.daecache Static mesh position · normal · colour · UV · tangent · UV2 · UV3
.xcache Skinned character mesh + skeleton + skin weights + animation
Installation
  1. Go to Edit → Preferences → Add-ons → Install…
  2. Select the io_bugsnax folder (zip it first if Blender asks for a zip).
  3. Tick "Bugsnax Cache (.objcache, .daecache, .xcache)" in the add-on list.
You'll get six new menu entries:
  • File → Import → Bugsnax Cache (.objcache)
  • File → Import → Bugsnax Cache (.daecache)
  • File → Import → Bugsnax Cache (.xcache)
  • File → Export → Bugsnax Cache (.objcache)
  • File → Export → Bugsnax Cache (.daecache)
  • File → Export → Bugsnax Cache (.xcache)
Static caches (.objcache / .daecache)
Importing
Option Default What it does
Scale 1.0 Uniform scale on the imported mesh
Import Textures On Loads referenced image files. If a texture isn't found on disk, a 1×1 placeholder is created so the path still round-trips when you export
Use Diffuse Alpha On Connect the diffuse texture's alpha channel to material alpha (alpha-clip cutout) when the texture genuinely contains transparency. Foliage and other cutout textures use this; fully opaque textures are left solid
The importer creates one mesh object with a Principled-BSDF material. Texture slots are wired up automatically: diffuse to Base Color, normal to Normal (via a Normal Map node), specular to Specular IOR Level. Cache files are Y-up; the importer rotates them to Blender's Z-up convention so they sit upright in the viewport.
When Use Diffuse Alpha is on, a diffuse texture that actually carries sub-1.0 alpha (leaf/foliage cutouts, fences, etc.) is wired through to the material's Alpha and the material is set to Alpha Clip with a 0.5 threshold — so only the genuinely transparent pixels are discarded and the rest of the surface stays solid. Fully opaque textures are detected and left untouched, so ordinary props don't go see-through.
Where the importer looks for textures
Cache files store asset-relative paths like Content/Models/Environment/Forest/Plants/PalmTree_D.dds. The importer searches:
  • The cache file's directory
  • Common subfolders: Textures/, tex/, textures/, Content/
  • Up to three parent directories
  • These extensions: .png .jpg .jpeg .tga .dds .bmp .tif .tiff .webp
Exporting
Selected Only Off Export only the selected mesh; otherwise the first mesh in the scene
Scale 1.0 Uniform scale on the exported mesh
Texture paths are read from the active material's Principled-BSDF inputs (the inverse of what the importer does). Asset-relative Content/... paths are preserved verbatim; anything else falls back to the file's basename.
Static-mesh conformity
Both static cache formats are single static mesh binaries. The exporter silently strips anything else, sampled at the current frame:
  • Armature modifiers are baked into the vertex positions via the depsgraph (current pose is what gets written)
  • Vertex groups / skin weights are dropped (no skin slot in the format)
  • Shape keys are evaluated at their current values before write
  • Animation actions are ignored (single-frame format)
When any of these is present, the export report (Blender's status bar) notes what was stripped. .objcache mirrors the OBJ format's limitations; .daecache is the DAE binary cache — DAE the source format supports skeletons, but the compiled cache does not.
If you need to keep the skeleton, animation, and skin weights, use .xcache instead.
Skinned cache (.xcache)
The .xcache importer builds a full rig: a mesh (optionally split into its internal sub-meshes), an armature, vertex-group skin weights, and an animation action. You can select and import several .xcache files at once.
Importing
Group Option Default What it does
Transform Scale 1.0 Uniform scale on the imported geometry
Transform Forward Axis -Z Forward axis used for the Y-up → Z-up conversion
Transform Up Axis Y Up axis used for the conversion
Geometry Import Normals On Apply the file's per-vertex normals
Geometry Import UVs On Apply the file's UV coordinates
Geometry Split Sub-Meshes On Split the xcache's internal multi-mesh structure into separate Blender objects
Geometry Weld Duplicate Vertices On Weld coincident verts so bone-deformation boundaries don't separate when animated
Geometry Infer Sharp Edges On Derive sharp edges from the imported normals
Materials Import Materials On Build Principled-BSDF materials
Materials Import Textures On Load referenced image files
Materials Use Diffuse Alpha On Connect the diffuse texture's alpha channel to material alpha (alpha-clip cutout) when the texture genuinely contains transparency
Rig Import Armature On Build the skeleton
Rig Import Weights On Apply skin weights as vertex groups
Rig Import Animation On Build an animation action from the file's keyframes
Rig Rest Pose Source Bind Pose Where bone rest poses come from (see below)
Rig Animation FPS 0.0 Playback rate; 0 lets the importer infer it from the file
Rig Set Scene Frame Range On Set the scene's start/end frames to match the animation
Rest Pose Source — Bind Pose (the default) reads the SkinWeights matrixOffset inverse-bind matrices, which is the correct interpretation for Bugsnax .xcache files. Frame Hierarchy instead walks the FrameTransformMatrix chain; use it only if a file imports with a broken rest pose under the default.
Texture search — the xcache importer extends the static-cache search with a cross-Content/ lookup: it walks up to find a Content ancestor directory and does a shallow scan of the subtrees beneath it, so a character in Content/Characters/Banana/ can still resolve a texture that actually lives under Content/Models/Bugs/Banana/.
Exporting
Include Selected Only Off Export only the selected objects
Include Apply Modifiers On Bake modifiers before writing
Include Export Armature On Write the skeleton
Include Export Weights On Write skin weights
Include Export Animation On Write the animation
Animation Range Frame Start 1 First frame to sample
Animation Range Frame End 250 Last frame to sample
Transform Scale 1.0 Uniform scale on the exported geometry
Transform Forward Axis -Z Forward axis for the Z-up → Y-up conversion
Transform Up Axis Y Up axis for the conversion
Round-trip behaviour
For the static caches, import → export produces a structurally identical file. Vertex counts, face counts, texture references, AABB, and the daecache extent all round-trip exactly. Byte-level equality isn't guaranteed (small metadata bytes are regenerated rather than carried verbatim) but the engine reads the result identically.
The daecache extras (UV2, UV3) are exposed in Blender as additional UV layers — keep those layer names intact if you want them preserved on export.
For .xcache, the importer/exporter were validated against a large dev corpus of Bugsnax character files; the mesh, skeleton, skin weights, and animation round-trip through Blender's armature/pose system.
File layout
io_bugsnax/
├── __init__.py           Blender operators and menu registration (all 3 formats)
├── parser.py             binary read/write — CacheMesh (.objcache / .daecache) + XNode (.xcache)
├── importer.py           .objcache / .daecache / .xcache → Blender object
└── exporter.py           Blender object → .objcache / .daecache / .xcache → file
What's New
1.0.1 June 14th, 2026
Blender Extension compliance fixes
Permissions
Developer
SaintBaron
Rating
Leave a review
Version
1.0.1
Updated
5 d
Published
June 2nd, 2026
Downloads
185
Size
91.0 KB
Blender 4.2 LTS and newer
Report Issues
github.com/SaintBaron/io_bugsnax
License
GNU General Public License v3.0 or later
Import-Export
...or download and Install from Disk
  • 91.0 KB
Reviews
See all
Be the first to review.
  • About
  • Terms of Service
About
  • Blender Foundation
  • Blender Institute
  • License
  • Logo & Trademark
  • Credits
  • Code of Conduct
Organization
  • People
  • Jobs
Blender Network
Download
  • Latest Blender
  • Blender LTS
  • Previous Versions
  • Experimental Builds
  • Source Code
  • Requirements
  • Benchmark
  • Flamenco
Extensions
  • Add-ons
  • Themes
Developers
  • Get Started
  • Roadmap
  • Docs
  • Forum
  • YouTube
  • Python API
  • Tools & Pipeline
Support
  • Community
  • FAQ
Get Involved
  • Education
News
  • Press Releases
  • User Stories
Blender Conference
Follow Blender
Support Blender
  • Donate
  • One-time Donation
