English, 简体中文.
Tutorial Video in English - At this site, a bit old but still useful.
Tutorial Video in Chinese 中文教程
Presets are nodes templetes that can be stored, modified, got.
You can manage & apply presets across .blend files:
Plus
icon button on the right of the preset select window. Current selected nodes will be saved to the new preset.Fast Create Preset Name
.Set
, these selected nodes will be saved to the current selected preset.Minus
icon button on the right of the preset select window.Up
/ Down
icon button next to the preset select window.Get
or in Shift + A
> Nodes
.Hot Node supports automatically opening, settings image file for node containing image, and supports the modes below:
Auto
- Try to open image with mode Similar
> Fixed Path
> Stay Empty
in order.Similar Name
- Find the best matched image according to the name similarity algorithm in user set folder.Name Key
- Find the best matched image according to user defined keys in user set folder.Fixed Path
- Open the same image with the original path.Stay Empty
- Don't open image.Settings of texutre loading:
Tolerance
- The tolerance of the image name comparation when the texture's mode is Similar Name
, higher means that more dissimilar images can pass the comparation and be loaded rather than using fixed path & stay empty. Default 0.50 as a moderate tolerance.Folder
- The directory path to try find images when in Auto
/ Similar
/ Keys
mode.To modify texture preset:
Textures
> Set
, select a Mode
for this image.Name Key
, you will need to enter key(s) for the image. You can have mutiple keys splited by /
, e.g. upper_body / base_color / .png
.Set Texture
button, and this image node will follow the new setting next time you apply the preset.Packs are folders storing presets.
Plus
icon button next to the pack slot.Collecetion
icon button on the left of the pack slot, choose one in the pop-up menu.Trash
icon button, the current selected pack will be deleted.Packs can be imported / exported as zip files. In Pack Import Export
panel:
Import
button to import pack(s). The waiting-for-import pack should be in .zip format.Recover
button to recover auto-saved packs from system's temp folder.Export
button to export the current selected pack as a zip file.Export All
button to export the all packs as zip files, useful for backup.For more tips of using Hot Node and bug reporting: Github - Hot Node
color_tag
, description
of NodeGroup can't be recorded.For Each Element
raises exceptions.This extension requests the following permission:
Import/export ZIP from/to disk, CRUD JSON at add-on path
This plugin is great, I really like it, thank you very much to the author, you have worked hard!
Thanks (‾◡◝)
Extremely useful. should be built into blender, if you like the Houdini HDA workflow of going file to file and your nodes changes being saved across them, this is the move
