Extensions
  • Home
  • Add-ons
  • Themes
  • Approval Queue
  • About
  • Upload Extension
  • Sign in
  • BLENDER.ORG
    • Download
    • What's New
    LEARNING & RESOURCES
    DEVELOPMENT
    • Developers Blog
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
All Add-ons
Add-on Grease Pencil to Curves
Quickly convert Grease Pencil strokes to simple curves and hair.
Add-on by DadsCastle
About What's New Reviews Version History
Grease pencil stroke converted to simplified Bezier curve Quick Demo of Addon
NOTE Now works with Blender 4.3 (use v0.1.2 for Blender 4.2 and below)
Grease Pencil to Curves add-on allows you to easily smooth the lines drawn with Grease Pencil in Blender, reduce the number of vertices, and convert to curves with one button. This eliminates a lot of work in shaping Bezier curves from scratch. You can also convert the resulting curve to a hair curve attached to a surface with a single click, allowing you to turn multiple grease pencil strokes into hair curves that are already aligned to the surface (giving you a head start in grooming). Each grease pencil layer creates a separate curve. You also have the option to resample generated curves to increase points. The add-on menu appears in the N-Panel within the "Edit" tab.
You can do all of this manually, but this addon does all the conversion, adjusting number of segments, smoothing, and attaching more easily in a single menu. In v0.4.3 of the addon, the smoothing menu was replaced with a button to invoke the Grease Pencil Smooth modifier. IMPORTANT: you need to 'apply' the smoothing modifier prior to converting to a curve since it's a non-destructive modifier.
In the addon overview on Youtube, I demonstrate a line drawn with Grease Pencil converted a curve to quickly create a chain and a string of lights. I then generate a whole head of hair from grease pencil strokes.
What's New
0.4.4 January 25th, 2025
This version adds a button for the 'Simplify' modifier so you can adjust the steps for reducing the number of curve spline vertices. This was already part of the pre-4.3 version of the extension (part of the UI panel), however the new grease pencil requires it to be invoked as a grease pencil modifier. You can edit the steps in the modifier properties panel. IMPORTANT: You must 'apply' the modifier prior to converting to curve if you want to keep the results.
See all versions
Permissions
Developer
DadsCastle
Rating
(1)
Version
0.4.4
Updated
5 mo
Published
March 29th, 2024
Downloads
28953
Size
6.8 KB
Blender 4.3 and newer
Website
dadscastle.gumroad.com/l/pkrsc
Report Issues
discord.gg/NnJ59E3Y
License
GNU General Public License v3.0 or later
Add Curve Modeling Grease Pencil
...or download and Install from Disk
  • 6.8 KB
Reviews
See all
  • danial-mahdi-soozani
  • v0.1.2
  • 7 mo
Amazing tool! I was trying to achieve this in geometry nodes but it wasn't working for me. Thanks!
5.0
1 review
5
4
3
2
1
Rate this Add-on
  • About
  • Terms of Service
Download
  • Latest Blender
  • Blender LTS
  • Blender Benchmark
  • Previous Versions
  • Experimental Builds
  • Source Code
  • Release Notes
  • Requirements
Organization
  • People
  • Jobs
About
  • Blender Foundation
  • Blender Institute
  • License
  • Logo & Trademark
  • Credits
Articles
  • News
  • Press Releases
  • User Stories
Get Involved
  • Dashboard
  • Development
  • Education
Support
  • Community
  • FAQ
Developers
  • Get Started
  • Docs
  • Forum
  • YouTube
  • Python API
Blender Conference
Follow Blender
Support Blender
  • Donate
  • One-time Donation
