Global Copy Nodes
Global Copy Nodes creates a global copy buffer for nodes that can be used across different sessions, and even different instances of Blender.
This add-on removes the need to save the node data manually. A simple copy and paste will do the trick!
Global Copy Nodes keeps references to data-blocks ensuring there is no data loss.
Add-on Preferences
Custom Copy Path
- Use Custom Copy Path (Boolean, default
False)
- Enables the use of a custom copy path, allowing you to copy across different.blend versions
- Custom Copy Path (String, directory type)
- The path to use to store the global copy buffer
Link to Scene
- Automatically Link To Scene (Boolean, default
True)
- Enables the automatic linking of attached objects or collections to the active scene. If disabled, they will be hidden until manually linked.
- Create Collections For Attached Objects (Boolean, default
True)
- If enabled, a default collection will automatically be created to nest objects or other collections under. If disabled, the scene collection will be used.
Internal Buffer
- Copy to Internal Buffer (Boolean, default
True)
- If enabled, it copies nodes to the internal and global buffer.
Add-on Operators
Global Copy Nodes
- Copies to the global copy buffer.
Ctrl + Shift + C by default
Global Paste Nodes
- Pastes from the global copy buffer.
Ctrl + Shift + V by default
Credits
Created by hisanimations
life changer, works very well!! thanks from Italy :)
