Extensions
  • Home
  • Add-ons
  • Themes
  • Approval Queue
  • About
  • Upload Extension
  • Sign in
  • BLENDER.ORG
    • Download
    • What's New
    DEVELOPMENT
    • Roadmap
    LEARNING & RESOURCES
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
All Add-ons
Add-on Export Curve To Json
File import/export for curves with JSON.
Add-on by Quint-Vrolijk
About What's New Reviews Version History
Example
A simple import/export addon to write curve data to JSON.
Import Usage
To import curves from JSON, do the following:
  1. Select a curve or curves you want to export.
  2. Go to File->Import->Import Curve (.json).
  3. Select the file you want to import.
  4. Select your desired import settings.
  5. And finally press 'Import Curve'.
Export Usage
To use this addon, do the following:
  2. Go to File->Export->Export Curve (.json). (If this option is disabled, check if you only have curve objects selected.)
  3. Select your desired export settings.
  4. Change the filename and filepath.
  5. And finally press 'Export Curve'.
Data Structure
Currently, it exports the following data:
  • Export Settings
    • world space coordinates (bool)
    • axis up (enum)
    • axis forward (enum)
  • Curves Data
    • object name (string)
    • type (Poly, Bezier, Nurbs) (enum)
    • spline length (float)
    • cyclic u (bool)
    • cyclic v (bool)
    • points data
      • tilt (float)
      • radius (float)
      • position [x, y, z]
      • handles (only if type is 'Bezier' ) [x, y, z]
For now, animations and shape keys are not included.
What's New
1.0.2 January 20th, 2026
  • Added import curve option
  • Added export scale parameter
  • Removed units parameter from export settings
See all versions
Permissions
Developer
Quint-Vrolijk
Rating
Leave a review
Version
1.0.2
Updated
5 mo
Published
Jan. 14th, 2026
Downloads
1256
Size
18.5 KB
Blender 4.2 LTS and newer
Report Issues
github.com/HerrWaffel/export_curve_to_json/issues
License
GNU General Public License v3.0 or later
Import-Export
...or download and Install from Disk
  • 18.5 KB
Reviews
See all
Be the first to review.
  • About
  • Terms of Service
About
  • Blender Foundation
  • Blender Institute
  • License
  • Logo & Trademark
  • Credits
  • Code of Conduct
Organization
  • People
  • Jobs
Blender Network
Download
  • Latest Blender
  • Blender LTS
  • Previous Versions
  • Experimental Builds
  • Source Code
  • Requirements
  • Benchmark
  • Flamenco
Extensions
  • Add-ons
  • Themes
Developers
  • Get Started
  • Roadmap
  • Docs
  • Forum
  • YouTube
  • Python API
  • Tools & Pipeline
Support
  • Community
  • FAQ
Get Involved
  • Education
News
  • Press Releases
  • User Stories
Blender Conference
Follow Blender
Support Blender
  • Donate
  • One-time Donation
