Essential brush settings like strength, size, blend mode and many others, are reset when Blender restarts. This add-on automatically saves and restores them. It supports brushes in Texture Paint, Sculpt, Vertex Paint, and Weight Paint modes.
ℹ️ Note:
This add-on performs brush save/restore operations both at Blender startup and on file save. As a result, loading times may be longer than usual.
This extension requests the following permission:
Save/Load configuration data JSON file to/from disk
God bless you. Thank you sooooooo much for making this add-on. You just saved me from so much fiddling.
simple and yet very important addon. Very annoying to loose the brush settings, this should be the default behaviour in b3d in my opinion. Thanks!
