I couldn't find this functionality in Blender, so I made this addon for the Graph Editor to solve it. It filters X, Y, Z for Translations, Euler/Quaternion* Rotations and Scales.
*Quaternion rotations comes non active by default, go to add-on preferences to activate it.
Added buttons to hide and unhide curves instead of default keymaps, made them for users who are not familiar with blender keymaps. You can use Shift+LMB to make multiple selections and Ctrl+LMB to subtract multiple selections.
Have fun :)
-Added support for Blender 4.4 -Fixed invoke error
I was searching for this long time ago ! I always use it in Maya. Thanks a lot for this ! A little thing that it could be great is the buttons can activate and deactivate when you clic on it (blue=1, Grey=0) It will be the cherry on the cake ! (french expression)
First of all, thank you very much for creating such a great plugin. Thank you. Then I found some problems. For example, this plugin seems to be unusable in blender 4.4. When I use it, an error will occur, such as Python: RuntimeError: could not create instance of GRAPH_OT_select_y_location_channel to call callback function 'invoke'
It will display the above. Can you help to modify it? Thank you very much
I updated yesterday and forgot to test in Blender 4.4 :)
It should be working if you update the extension now. Have fun animating :)
This addon is great! Simple yet necessary functionality, the only thing I'd like to point out is that it seems to not work when used along-side the brand new slotted actions, I hope this gets fixed at some point :)
