Extensions
  • Home
  • Add-ons
  • Themes
  • Approval Queue
  • About
  • Upload Extension
  • Sign in
  • BLENDER.ORG
    • Download
    • What's New
    LEARNING & RESOURCES
    DEVELOPMENT
    • Developers Blog
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
All Add-ons
Add-on 3D Cursor Plus
3D Cursor Plus
Axes, undo and few other tools for your 3D Cursor.
Add-on by chokavr
About What's New Permissions Reviews Version History
Cursor Gizmo Cursor Undo PLUS Keymap Keymap PLUS Operators User Shortcuts PLUS Override PLUS Panel Ops
Axes / Gizmo
If you ever wanted to see the cursor's axes more clearly or to have a gizmo for easier manipulation, here they are. You'll have two separate presets; use any or both, and toggle between them with a shortcut, a button on a panel, or a pie menu. Adjust them to fit your needs: change colors and sizes, choose the desired behavior for each preset, define visibility in separate areas, link with the 3D cursor, or use it instead of the cursor.
GizmoAxes
If enabled, makes Undo and Redo work for your 3D cursor too. For the sake of simplicity, this function only considers changes in these three parameters: Cursor's Location, Euler Rotation and Rotation Mode. Changes in its Quaternion and Axis Rotations are ignored due to their redundancy, cursor-wise.
Change detection has a tiny (~0.3 sec) delay to filter out unnecessary transformations. So, if you attempt a 'rapid' cursor placement (more than 3 per second), probably only the last one will be detected. This limitation does not apply to Undo and Redo operations themselves.
Cursor Related Operators
PLUS Operators are intended to streamline your workflow by providing easy access to default Blender operators that have been slightly tweaked to work with reference to the 3D Cursor. They work both in 'Object' and 'Edit' modes, and some of the operators have modifiers that can alter their default behavior if 'SHIFT' or 'ALT' is held prior to calling them.
Snap To (with Op Modifiers)
Move your 3D cursor with the 'Snap' option enabled and a separate 'Snap List', independent from your global snap options.
  • Tweak Snapping: You can choose elements to snap to via panel, pie menu, or shortcuts, and enable or disable 'Aligning Rotation to Target'.
  • SHIFT: temporarily invert the current rotation mode.
  • ALT: snap with the cursor rotation reset on start.
SnapTo
Move
Move the selection along the 3D cursors axes. The default is the Z axis.
Move
Rotate
Pivot the selection around the 3D cursor.
Rotate
Scale
Scale the selection using the 3D cursor as a transform point.
Scale
Copy Rotation
Copy the rotation of the 3D cursor to the selected object(s).
CopyRotation
Reset 3D Cursor (with Op Modifiers)
Clear the 3D cursor rotation, location, or both(by deafult).
  • SHIFT: Reset only rotation.
  • ALT: Reset only location.
  • SHIFT+ALT: Call the built-in 'Center Cursor and Frame All' function (default shortcut: Shift+C).
ResetCursor
Override (with Op Modifiers)
Override the current Transform Orientation and/or Pivot Point to 'Cursor'. It is possible to assign to the pie menu a callable 'Override' panel with 3 separate buttons, or to use the 'Override' as a single button with two available modifiers:
  • SHIFT: Override Transform Orientation.
  • ALT: Override Pivot Point.
    By default, it will do both.
OverRide
What's New
1.0.4 March 27th, 2025
BugFix: 'Undo' were still working after disabling it in preferences and restarting the Blender.
See all versions
Permissions
This extension requests the following permission:
  • Files
    Save/Load gizmo presets and Pie menu configuration
Developer
chokavr
Rating
(11)
Version
1.0.4
Updated
2 mo
Published
Dec. 24th, 2024
Downloads
13285
Size
77.7 KB
Blender 4.2  and newer
Report Issues
github.com/chokavr/3D-Cursor-plus/issues
License
GNU General Public License v3.0 or later
3D View
...or download and Install from Disk
  • 77.7 KB
Reviews
See all
  • Eric-Weulacy-Craveiro-de-Souza
  • v1.0.4
  • 6 d
  • Ibra-5
  • v1.0.4
  • 2 w
A simpel yet VERY USEFUL addon on, if you are tierd of wasting your time a get this addon.
  • Martin-Sýkorský
  • v1.0.4
  • 1 mo
This makes me wanna use the 3D cursor!
5.0
11 reviews
5
4
3
2
1
Rate this Add-on
  • About
  • Terms of Service
Download
  • Latest Blender
  • Blender LTS
  • Blender Benchmark
  • Previous Versions
  • Experimental Builds
  • Source Code
  • Release Notes
  • Requirements
Organization
  • People
  • Jobs
About
  • Blender Foundation
  • Blender Institute
  • License
  • Logo & Trademark
  • Credits
Articles
  • News
  • Press Releases
  • User Stories
Get Involved
  • Dashboard
  • Development
  • Education
Support
  • Community
  • FAQ
Developers
  • Get Started
  • Docs
  • Forum
  • YouTube
  • Python API
Blender Conference
Follow Blender
Support Blender
  • Donate
  • One-time Donation
