This adds a simple operator to copy object names to object data. It will appear in the right-click context menu in the Outliner.
Often, when naming objects (the orange part) it is helpful to give the data (the green part) a matching name. This add-on makes this task much easier.
Add inverted option for copying data name to object.
Very helpful!
Constant problem I run into when searching for certain objects when appending etc. Especially helpful when animating in Grease Pencil! Thanks so much for this.
