Extensions
  • Home
  • Add-ons
  • Themes
  • Approval Queue
  • About
  • Upload Extension
  • Sign in
  • BLENDER.ORG
    • Download
    • What's New
    DEVELOPMENT
    • Roadmap
    LEARNING & RESOURCES
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
All Add-ons
Add-on Camera Aspect Ratio Guides
Professional composition guides with safe areas.
Add-on by Prince_Eagle
About What's New Permissions Reviews Version History
Camera Aspect Ratio Guides - Walkthrough
Professional composition guides with viewport overlays, safe areas, and optional render burn-in for Blender 5.0+
📋 Overview
Camera Composition Guides Pro provides real-time composition overlays in your camera viewport with the ability to burn guides directly into final renders. Perfect for cinematographers, motion graphics artists, and anyone working with multiple aspect ratios or delivery formats.
✨ Key Features
🎯 Composition Guides
  • Rule of Thirds - Classic grid composition
  • Golden Ratio - Phi-based composition (1:1.618)
  • Golden Triangle - Diagonal composition guides
  • Diagonals - Corner-to-corner guides
  • Center Cross - Horizontal and vertical center lines
  • Harmonious Triangles - Advanced triangular composition
📐 Aspect Ratio Presets
  • Multiple simultaneous aspect ratios in one view
  • Custom width/height settings per preset
  • Optional thirds and center line overlays per ratio
  • Passepartout (black bars) for accurate framing visualization
  • One-click common presets: 16:9, 9:16, 1:1, 4:3
🛡️ Safe Areas
  • Action Safe - 90% default safe zone
  • Title Safe - 80% default safe zone
  • Custom - Define your own percentages
  • Essential for broadcast and streaming deliverables
🎨 Customization Options
  • Line Styles: Solid, Dashed, or Dotted
  • Adjustable Colors: Per-guide RGBA color control
  • Line Width: Customize thickness for each guide
  • Independent Controls: Enable viewport display and render burn-in separately
🔥 Render Burn-In
How It Works
  1. Enable any composition guide, safe area, or aspect ratio preset
  2. Check the "Burn into Render" checkbox for guides you want in your final output
  3. Render normally (F12) - guides are automatically composited into the image
  4. Uncheck "Burn into Render" when you want clean renders
Smart Compositor Integration
  • Non-destructive: Inserts nodes into your existing compositor setup
  • Automatic cleanup: Removes guide nodes when you disable "Burn into Render"
  • Regenerate button: Manually refresh guides if settings change or resolution updates
  • Preserves your existing compositor node tree
⚠️ Important Notes
  • Always save your .blend file before rendering with burn-in enabled
  • If you render with "Burn into Render" ON, then turn it OFF, press the Regenerate button to ensure compositor is properly updated
  • Guide nodes remain in compositor after unchecking until you press Regenerate - this is intentional for render consistency
  • The addon does NOT delete your existing compositor setup - it only inserts guide nodes between your current chain and the output
🎬 Perfect For
  • Cinematographers planning multi-format deliverables (theatrical, streaming, social media)
  • Motion Graphics Artists creating content for Instagram, TikTok, YouTube simultaneously
  • Animators working with multiple aspect ratios for different platforms
  • Client Presentations with visible framing references for approval
  • Film & Video Production pre-visualization and shot planning
  • Broadcast Work ensuring content stays within safe areas
🚀 Quick Start Workflow
  1. Add Guides: Select your camera → Camera Properties panel → Composition Guides section
  2. Viewport Display: Enable the checkbox next to any guide to see it in camera view (Numpad 0)
  3. Customize: Adjust colors, line styles, and widths to match your needs
  4. Render Burn-In (Optional): Check "Burn into Render" for guides you want in the final image
  5. Render: Press F12 - guides are automatically composited if burn-in is enabled
  6. Clean Renders: Uncheck "Burn into Render" and press Regenerate for clean renders
📍 Location
Camera Properties Panel → Composition Guides section
Visible only when a camera object is selected.
🔧 Technical Details
Rendering
  • Only guides with "Burn into Render" checked are included in F12 renders
  • Compositor integration happens at render_init - after scene setup but before rendering
  • Cleanup happens when you disable "Burn into Render" (requires clicking Regenerate)
  • Guide image is generated at exact render resolution for pixel-perfect accuracy
Regenerate Button
Use this button when:
  • Changing render resolution
  • Modifying guide colors, widths, or styles
  • After disabling "Burn into Render" to clean up compositor
  • Switching between different guide configurations
  • Things seem out of sync
⚙️ Requirements
  • Blender 5.0.0 or higher
  • Camera object in scene
  • For render burn-in: Compositor enabled (automatically handled by addon)
🛟 Support & Tips
Guides not showing in viewport?
  • Press Numpad 0 to enter camera view
  • Ensure guide is enabled (checkbox on the left)
Guides not rendering?
  • Check "Burn into Render" is enabled for that guide
  • Press Regenerate button before rendering
  • Verify compositor is enabled in scene
Compositor has extra nodes after render?
  • This is normal if you haven't disabled "Burn into Render" yet
  • Disable "Burn into Render" and click Regenerate to clean up
Want clean renders after using burn-in?
  • Uncheck ALL "Burn into Render" boxes
  • Click the Regenerate button
  • Now renders will be clean
What's New
2.0.0 January 25th, 2026
Version 2.0.0
  • Added composition guide types (Golden Ratio, Diagonals, etc.)
  • Added safe area overlays (Action Safe, Title Safe, Custom)
  • Added line style options (Solid, Dashed, Dotted)
  • Added Regenerate button for manual refresh
  • Blender 5.0 compositor compatibility
  • Fixed non-destructive compositor integration
  • Fixed cleanup to preserve user's compositor nodes
  • Improved render burn-in workflow with explicit user control
See all versions
Permissions
This extension requests the following permission:
  • Files
    Modify compositor nodes for render burn-in
Developer
Prince_Eagle
Rating
(5)
Version
2.0.0
Updated
5 mo
Published
Nov. 5th, 2025
Downloads
8675
Size
11.4 KB
Blender 5.0
Unsupported
5.5 and above
Report Issues
github.com/PrinceEagle/Camera-Aspect-Ratio-Guides.git
License
GNU General Public License v3.0 or later
Compositing Render Camera
...or download and Install from Disk
  • 11.4 KB
Reviews
See all
  • Ross-Owens
  • v2.0.0
  • 1 mo
This add-on works great for creating compositions with different aspect ratios.
My only suggestion would be to add more controls for offsetting and scaling the guide in the aspect ratio settings. If I'm rendering a shot square with the intent to crop it for horizontal and vertical ratios, I don't always want the crop to be centered in the render area.
  • n8mac
  • v2.0.0
  • 2 mo
Nice improvement over the default options. I don't see a way to add a safe area that has a different aspect ratio than the outside frame. As in control the X and Y dimensions separately.
  • teherauto
  • v1.0.5
  • 5 mo
Useful, but very missing the golden ratio (too). Blender's own ratio's are very good, it would be enough to just change their color and the thickness and type of line (smooth, dashed, dotted, etc.).
  • Prince_Eagle replied
  • 5 mo
I've updated the addon and it should have all the features you were missing. I hope this helps.
5.0
5 reviews
5
4
3
2
1
Rate this Add-on Report an issue
  • About
  • Terms of Service
About
  • Blender Foundation
  • Blender Institute
  • License
  • Logo & Trademark
  • Credits
  • Code of Conduct
Organization
  • People
  • Jobs
Blender Network
Download
  • Latest Blender
  • Blender LTS
  • Previous Versions
  • Experimental Builds
  • Source Code
  • Requirements
  • Benchmark
  • Flamenco
Extensions
  • Add-ons
  • Themes
Developers
  • Get Started
  • Roadmap
  • Docs
  • Forum
  • YouTube
  • Python API
  • Tools & Pipeline
Support
  • Community
  • FAQ
Get Involved
  • Education
News
  • Press Releases
  • User Stories
Blender Conference
Follow Blender
Support Blender
  • Donate
  • One-time Donation
