Extensions
  • Home
  • Add-ons
  • Themes
  • Approval Queue
  • About
  • Upload Extension
  • Sign in
  • BLENDER.ORG
    • Download
    • What's New
    LEARNING & RESOURCES
    DEVELOPMENT
    • Developers Blog
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
All Add-ons
Add-on Brushstroke Tools
Brushstroke Tools
Brushstroke painting tools by the Blender Studio.
Add-on by Blender Studio
About What's New Permissions Reviews Version History
Painterly fishing hut scene created using the Brushstroke Tools extension for the introductory workshop available on studio.blender.org Screenshot of the fishing hut demo file open in Blender interactively rendered with Eevee Brushstroke Tools setup with the Blender Studio fish asset from Project Gold. There are multiple brushstroke layers visible. Three fill layers with different purpose and one draw layer. There is a dedicated brush drawing tool in the toolbar on the left. Supercut of the workshop using the addon available on studio.blender.org
Set of tools for a painterly 3D brushstrokes workflow by the Blender Studio to create a variety of stylized looks for asset production.
Watch the introduction video here!
Overview
This addon provides a convenient interface to create, manage and edit layers of 3D brushstrokes that are generated procedurally with an elaborate Geometry Nodes system.
There are two types of Brushstroke Layers:
  • Fill
Flood a mesh surface with brushstrokes and control them with a wide set of parameters in the 'Shape' panel of the addon interface. This type of brushstroke layer can be guided by drawing curves for the flow direction or marking parts of the mesh to define flow/break edges and faces to be ignored using the shortcut Ctrl+Alt+F.
  • Draw
Draw brushstrokes as curve geometry directly on a surface mesh. There are settings in the toolbar as you draw to control, for example, the color. On top of that you can apply additional procedural effects in the 'Shape' panel of the addon interface.
Material
The material of a brushstroke layer can also be controlled using the addon interface. Material settings are split into
  • Properties (Base PBR setup to control material quality)
  • Brush Style (Selection and control of the base texture from real-life scans)
  • Effects (Additional masking effects to adjust the texture)
More Info
  • Watch the guided workshop and download the fishing hut example file
  • Find more extensive documentation here
Consider supporting our work and get all kinds of useful resources regarding production with Blender by subscribing to the Blender Studio
Disclaimers
The geometry generation and rendering techniques applied with this extension are computationally intensive and rely on high-end hardware specifications to allow smooth workflow.
For Blender 4.2.0 to 4.2.3 you might have to restart Blender once after installing the extension to ensure all assets are available.
Brush style previews only work for Blender versions 4.2.4 and up.
FAQ
  • Why does the fill layer not react to me drawing the flow curves?
    • Most likely you don't have a valid UV map on your surface mesh. Try doing a simple Auto-UV unwrap and adding the fill layer again.
  • Why is the fill layer reacting badly and inaccurately to the drawn flow curves?
    • Most likely your surface mesh has a low resolution. The flow requires a certain mesh resolution to be interpolated properly.
  • I am using Cycles for rendering and there are black spots all over the place.
    • This method of stylized rendering makes heavy use of overlapping transparent planes. This means Cycles need to do a high number of transparent bounces for the image to resolve nicely during rendering. To help with this setting you can use the Render Setup operator in the Advanced panel.
  • I'm experiencing poor performance. How can this be avoided?
    • This method is computationally intensive and relies on high level hardware to run smoothly. But there are a few things that can be done to avoid low perfromance.
    • If it's about tweaking shape parameters, then it doesn't have to do with the rendering, but is about the geometry evaluation and it just helps to keep the amount of brushstrokes and their resolution low, to reduce the amount of geometry that needs to be processed.
    • If just in the static case, orbiting the camera is slow, then it has to do with Eevee and keeping the amount of pixels that need to be rendered low helps most. For example you can change the Pixel Size in the Performance - Viewport settings. Samples don't help with interaction, since during that only 1 sample is rendered anyways.
What's New
1.1.1 January 17th, 2025
FIXED
  • fix losing brushstroke context material on new preset initialization (#365)
  • fix accumulation of default brush style datablocks (#366)
  • fix handling of incremental suffix on brush style datablocks (#366)
See all versions
Permissions
This extension requests the following permission:
  • Files
    Read/write brushstroke asset resources from/to disk
Team
Rating
(58)
Version
1.1.1
Updated
5 mo
Published
Nov. 4th, 2024
Downloads
63534
Size
28.3 MB
Blender 4.2  and newer
Website
studio.blender.org/tools/addons/brushstroke_tools
Report Issues
projects.blender.org/studio/blender-studio-pipeline
License
GNU General Public License v3.0 or later
Material Paint Geometry Nodes
...or download and Install from Disk
  • 28.3 MB
Reviews
See all
  • Wade-Schneider
  • v1.1.1
  • 2 w
Great addon, How ever recently its been spamming my console with /home/$USER/.config/blender/4.4/scripts/addons/brushstroke_tools/__init__.py Every time i hover over a UI element.
$USER is replaced by a users username, i added that in as its agnostic
Great tool though still worth the 5 stars i gave it, would like that error to disappear. I added a bl_info section to the said script as a test but that didnt work so im assuming it needs something else.
  • SimonThommes replied
  • 1 d
It would be helpful if you could create a bug report with more info here: https://projects.blender.org/studio/blender-studio-tools/issues/new?template=.gitea%2fissue_template%2fbug.yaml
I can't reproduce the issue at this time.
  • tone-watson
  • v1.1.1
  • 2 w
incredible
  • Theanine3D
  • v1.1.1
  • 1 mo
Simply amazing. Really impressed with this and can't believe the Blender Studio was kind enough to provide it for free. It's surprisingly easy/qiuck to get a nice looking result with this addon.
5.0
58 reviews
5
4
3
2
1
Rate this Add-on
  • About
  • Terms of Service
Download
  • Latest Blender
  • Blender LTS
  • Blender Benchmark
  • Previous Versions
  • Experimental Builds
  • Source Code
  • Release Notes
  • Requirements
Organization
  • People
  • Jobs
About
  • Blender Foundation
  • Blender Institute
  • License
  • Logo & Trademark
  • Credits
Articles
  • News
  • Press Releases
  • User Stories
Get Involved
  • Dashboard
  • Development
  • Education
Support
  • Community
  • FAQ
Developers
  • Get Started
  • Docs
  • Forum
  • YouTube
  • Python API
Blender Conference
Follow Blender
Support Blender
  • Donate
  • One-time Donation
