Extensions
  • Home
  • Add-ons
  • Themes
  • Approval Queue
  • About
  • Upload Extension
  • Sign in
  • BLENDER.ORG
    • Download
    • What's New
    LEARNING & RESOURCES
    DEVELOPMENT
    • Developers Blog
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
All Add-ons
Add-on Path Maker
Path Maker
Replaces custom tags in the Output Path.
Add-on by thornydre
About What's New Reviews Version History
Preferences examples Render path example to use the previously set tags These buttons will replace the File Path parameter
The "Path Maker" add-on allows you to write tags in some output paths. Tags will be replace at render time by a string generated with a line of code, a python script or an hardcoded string.
It supports:
  • The "Output Path" in the output properties panels
  • The "Base Path" in the file output compositor nodes
  • The "filepath" in the collection exporters (you'll have to use the Path Maker buttons to make it work though)
Tag Type dropdown:
  • Expression: single line python expression (example: bpy.context.scene.name)
  • Path: Hard coded path (example: toto\hello\world)
  • Script: Path to a python script that will be interpreted (the script has to print the value)
For example: The tag <filename> can be replace by "bpy.path.display_name_from_filepath(bpy.data.filepath)" so that an Output Path like "C:/hello/<filename>/world" will now be "C:/hello/file_name/world".
What's New
1.4.1 March 27th, 2025
  • Simplify <filename> default tag
See all versions
Permissions
Developer
thornydre
Rating
(10)
Version
1.4.1
Updated
3 mo
Published
March 17th, 2024
Downloads
8645
Size
4.1 KB
Blender 4.2 LTS and newer
License
GNU General Public License v3.0 or later
Render
...or download and Install from Disk
  • 4.1 KB
Reviews
See all
  • Gray543
  • v1.4.1
  • 4 w
Very useful! Is it possible to set name of the filename, not just the /folder? I got it working with png, but can't see a 'file subpath' option for exr output?
  • thornydre replied
  • 4 w
The EXR output path work's the same as PNG. You can have a path like "C:/hello/world/image_###.exr" The folder would be "C:/hello/world/" and the filename would be "image_####.exr" where #### is the frame number. And you can use the add-on in either of these parts of the path.
  • Christian-V
  • v1.4.1
  • 1 mo
I really like that addon, since it makes Output Paths behave like Maya and it should be Standard.
At first it worked. After Rendering an Animation in Evee it replaced the Token with the full output path.
Afterward it didn´t work anymore. I get the error message "could not open file for Rendering".
This workflow should be standard in Blender. I really hope the dev make it happen
  • thornydre replied
  • 1 mo
Hi, Thanks for the review :) I didn't manage to reproduce the error, do you think you could provide the tokens you are using, and the output path with the token written in it when you have the error ? And if it is possible, a copy of the error message from the console (the one you can show by going to "Window > Toggle System Console"). Thanks again !
  • TrobyBoy
  • v1.3.5
  • 3 mo
This addon is exactly what I was looking for, and I was so glad to find it as a listed extension. Thank you! Makes the pipeline and versioning way smoother and aligned with the standards of other CGI and compositing software. I have to say that for me it was a bit cryptic to understand how to use the expression, but thanks to LLMs that was an easy ask. I would love to see the implementation of easy-to-add commonly used expressions. In my case I set up expressions for camera name, scene name, view layer name, filename, and version (last 4 digits of the filename, in my case "_v03" or "_v04" etc.
Only issue I encountered so far is that in one file, all tokens keep being replaced by the expression's result, and so I end up having to manually update every time I reopen the file, which kind of defies the purpose. Haven't really understood why this seem to happen with one specific file yet.
  • thornydre replied
  • 3 mo
Hi, thanks a lot for the review, I am working on some defaults preferences at the moment, it should be ready soon. For the issue with the tokens being replaced, does this happen when you are doing a specific action ? Juste rendering ? Interupting the render maybe ? If you can tell a bit more details about when this happens I'll have a look into it.
5.0
10 reviews
5
4
3
2
1
Rate this Add-on
  • About
  • Terms of Service
Download
  • Latest Blender
  • Blender LTS
  • Blender Benchmark
  • Previous Versions
  • Experimental Builds
  • Source Code
  • Release Notes
  • Requirements
Organization
  • People
  • Jobs
About
  • Blender Foundation
  • Blender Institute
  • License
  • Logo & Trademark
  • Credits
Articles
  • News
  • Press Releases
  • User Stories
Get Involved
  • Dashboard
  • Development
  • Education
Support
  • Community
  • FAQ
Developers
  • Get Started
  • Docs
  • Forum
  • YouTube
  • Python API
Blender Conference
Follow Blender
Support Blender
  • Donate
  • One-time Donation
