Automatically limit paint strokes to clean, connected face regions.
Click a face and the add-on selects the correct area based on your chosen boundaries, enables Face Masking, and lets your normal brush handle the rest.
Supports:
On click:
No manual face selection. No replacement tools. Just controlled paint.
Toggle boundaries and pin masks directly from the tool header. Configure default settings and custom shortcuts in the addon preferences.
Enable the boundaries you need:
Topology
Surface
Edge Attributes
Rules can be combined (for example: Sharp + UV Seams).
Single Face always limits the result to exactly one polygon.
Keep the mask between strokes instead of clearing it automatically.
Useful for building up complex paint areas without switching modes. When working with masks you can use ctrl + numpad +/- to grow or shrink the selection, and ctrl + I to invert it.
Save face selections as named presets directly on the object. Reload them later with one click.
Open the addon preferences (Edit → Preferences → Extensions → Auto Paint Boundaries) to:
If this add-on saves you time or improves your workflow, you can support continued development here:
Added Paint tag to manifest
