Once the extensions has been installed and enabled, there should be a new side tab in the shader editor
Fill in the material name and the resolution. By default, it fills in Rock035, but you can chose any other material id. The material id is basically the displayed material name without space, as it appears in the URL.
Click on Fetch and Create Material. Wait for the material to be fetched - depending on the resolution and your connection, it should take anywhere from 5s to 1mn. You'll then be able to select the material from the dropdown. It sets up color, metalness, roughness, normal map, displacement, and a mapping node.
Note that downloads are cached to <home>/.cache/ambientcg (for example, on windows, if your username is nino, downloads are cached in C:\Users\nino\.cache\ambientcg, and on unix, /home/nino/.cache/ambientcg), so if you already downloaded the texture, even in another blender file, it should skip the download this time! This folder location can be edited in the addon preferences.
Made with <3 by Nino Filiu
Enable cache folder parametrization
This extension requests the following permissions:
Import and cache textures to disk
Makes calls to AmbientCG
Great to have at least one addon doing this in the extensions platform, wish it supported more sites like the lily surface scrapper addon which looks unalive
Yeah in my free time I'm trying to support more engines and more endpoints! I already coded the UE version of this plugin already :)
It is perfect, thank you.
