- DragonDreams GmbH changed review status to Awaiting Review
- 1 mo
Extension is ready for initial review
The Blender DEMoCap Tools Addon simplifies the process of importing motion capture animations created by DEMoCap. Both free captures as well as exported captures are supported.
See Wiki Add-On Page for informations on how to import motion capture created with DEMoCap as well as using tools like correction bones.
See Wiki Live-Connection Page for information on how to use live connection support to stream motion capture from DEMoCap directly into Blender without importing.
Fixed problems with bone groups not existing anymore in Blender 4.0
This extension requests the following permissions:
Add-on expects to have access to filesytem.
Add-on expects to have internet access.
Hi, thanks for submiting the add-on.
According to the terms of service this platform requires all the extensions to be self-contained. This add-on is a bit on the edge since its dependency is another add-on hosted on the same platform.
That said, it would be ideal if you could make it fully independent (so e.g., they don't go out of sync). Some ideas:
I could include the export/import extension into this one. I have only one concern with it. If somebody installs also the export/import extension the operator names would clash (since they are global in Blender) leading to problems. On the other hand if I rename the operators to avoid the clashing they would be duplicate potentially confusing the user. What do you think is the best solution for this problem?
The most elegant way would be to check if operators with their names (and panels, and everything else …) are already registered before registering them.
You will need to do this on both add-ons since you don’t control which one Blender will register first.
Something else, I think this add-on is not unregistering itself. If I enable it and then disable it, the tab on the 3D Viewport doesn't go away.
This is strange. It uses the same auto-register code. I'll look into it.
Applied the requested fixes and embedded the "Drag[en]gine Import Export" extension in a way it does not conflict (version 1.22.2 or newer)
Sign in to comment.
