A convenient animation plugin designed to address some of the inconveniences encountered when creating animations in Blender. Currently, it offers the following functionality: exporting grease pencil layer content from Blender as sequenced keyframes, and generating a CSV timing sheet file.
blender_manifest has been modified
This extension requests the following permission:
Output CSV and sequence diagram
Hello, can you new images with English interface?
Render pop-up panel seems to be broken, can you fix that? https://imgur.com/P1uueGy
Also, it would be good if default string for LayerTag was in English
Hello, based on your feedback, I have made the scripts and interface entirely in English. I have removed the pop-up window from the rendering panel and retained the original Blender output path and output operation method. The tag settings have been moved to the plugin settings panel. Now, you only need to click just like in your usual Blender rendering process.
Approved
I just missed that this doesn't have Files permission specified. All exported should have permission for that in blender_manifest
Thanks
Sign in to comment.
