Import CSV or JSON data into blender spreadsheet.
The data can then be processed with geometry nodes to be visualized.
File / Import / Spreadsheet Importer
icon to the right of the listTo use the imported data in any geometry nodes tree, add an Object Info node and select the object containing the imported data in the object field.
If later you want to replace the data, you can do this in the object data properties of the selected object: Link another mesh data block to the object, and the values will update. If used column names still exist in the newly linked data block, everything should update as expected.
A single float value named "field_name" is used to scale some cubes.
The Domain Size node is used to find the amounts of bars needed (the size of the imported dataset), and a duplicate of the bar geometry is created for each row of data. The duplicates are then ofset along the X axis according to the duplicate index, and scaled along the Z axis according to the data sampled from the "field_name" comumn where the row matches the duplicate index.
Sample CSV Data:
"T 08.02.01.01.01";;;;;;;;
"Endenergieverbrauch nach Energieträger";;;;;;;;
"Tausend Terajoules";;;;;;;;
;"Total";"Brennstoffe";"Treibstoffe";"Elektrizität";"Gas";"Kohle";"Holz und Holzkohle";"Übrige Energieträger"
"2010";"905.17";"190.41";"295.08";"215.23";"115.94";"6.21";"40.93";"41.37"
"2011";"844.34";"150.85";"296.59";"210.96";"104.21";"5.74";"35.62";"40.37"
"2012";"875.82";"161.13";"299.85";"212.3";"114.32";"5.17";"39.44";"43.61"
"2013";"897.88";"168.46";"299.77";"213.56";"120.79";"5.57";"43.46";"46.27"
"2014";"827.99";"127.55";"298.26";"206.88";"107.13";"5.7";"36.73";"45.74"
"2015";"840.71";"133.89";"290.53";"209.69";"112.93";"5.21";"39.15";"49.31"
"2016";"856.43";"136.35";"291.82";"209.66";"117.24";"4.79";"42.32";"54.25"
"2017";"852.26";"127.93";"290.1";"210.54";"118.91";"4.61";"42.72";"57.45"
"2018";"833.25";"115.63";"294.3";"207.53";"112.31";"4.29";"40.45";"58.74"
"2019";"836.23";"112.31";"294.36";"205.91";"115.21";"3.81";"41.08";"63.55"
"2020";"747.9";"101.11";"226.72";"200.57";"112.9";"3.66";"39.86";"63.08"
"2021";"794.72";"111.71";"233.21";"209.21";"122.28";"3.7";"46.39";"68.22"
"Letzte Änderung: 27.07.2022";;;;;;;;
"Quelle: BFE � Gesamtenergiestatistik";;;;;;;;
"� BFS 2022";;;;;;;;
The imported Data viewed in the spreadsheet editor:
No changelog for this release.
This extension requests the following permission:
Load CSV and JSON files from disk
Hi, this is the https://extensions.blender.org/approval-queue/blender-spreadsheet-import/ with updated ID. I hope it's all right like this. I'll delete the other version if so. Cheers, Simon
Approved. You can delete the other one.
Sign in to comment.
Ready for review
