- BlenderCN-LJ changed review status to Awaiting Review
- 1 w
This is an addon for Blender that enhance simple deform modifier. A visualize simple deform tool
·Support Gizmo
·Support automatic upper and lower limit matching for all modes
·Support one click correction of bending deformation orientation
To display gizmos, you need select an object then add a simple deform modifier.
Red gizmo: Upper limit
Green gizmo: Lower limit
purple gizmo: Deform strength
When draging gizmos, you can pres X/Y/Z to lock on axis, hold Ctrl to keep relative distance
And, you can change origin control mode at tool settings to change limit behaviors, you can also scroll when dragging to change it quickly.
Not able to support multiple SimpleDeform modifiers well, especially with overlapping deformation areas.
V0.2.2
This extension requests the following permission:
Read Gizmo Data
This is a feature that Blender should have on its own. When Blender officially launched this feature, I deleted it
As its usually the case with your add-ons it's very creative coding, but potentially at performance cost. Running timers that often at that speed isn't neglegable. I'll approve but I want this to be documented in description very prominently, that this can cause slowdowns to the complex scenes.
I understand this and I will continue to optimize it. What we are currently working on is a local Z rotation bending support
Sign in to comment.
Ready for review
